Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
camgrinder's Avatar
356 Camshafts
Is anyone looking for the HCP camshafts?
John Dougherty
Dougherty Racing Cams
Old 04-13-2004, 03:57 PM
I was hoping to get one at the auction, but they cancelled overseas bids.
Still interested!
How much?
Kelvin '67 912
New Zealand
Old 04-17-2004, 03:26 AM
camgrinder's Avatar
We have them on new wide lobe chill cast castings, or can regrind it for you on a good used core.
PM me for prices.
Thanks John
John Dougherty
Old 04-17-2004, 08:04 AM
what exactly is the HCP camshaft. I am looking for a cam shaft that would better suit by 912 engine with a big bore kit. (86mm, ~9.2:1CR) Let me know if you have this or can grind one for me. thanks.
Old 04-29-2004, 06:08 PM
camgrinder's Avatar
Hi, the HCP camshaft is a 266 degree grind I used to do for Harry Pellow.
For your engine our 280 grind works well.
I can grind your camshaft or grind a new wide lobe casting.
John Dougherty
Old 04-29-2004, 06:42 PM
Two Questions,
What do you recomend for a Super 90 with big bore kit for street driving? Need good low end due to living in the mountains of Tennessee!
Also, can you give me any contact information for Harry's machine shop guy? I think it was Jay? I need to get the work on done on the Super 90 block and heads.
Thanks,
Jerry in Nashville
Old 04-30-2004, 10:03 AM
camgrinder's Avatar
Jay is in Santa Clara CA. I dont have the number handy, his area code is 408
With a big bore kit use the 280 grind on a 110 lobe center. set the compression ratio at 9-1. The power band will be strong from 2000 to 6000 rpms.
John Dougherty
Old 04-30-2004, 05:12 PM
cam grinder, you have a PM
Old 05-20-2004, 12:42 PM
