Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
earlr85944's Avatar
fan shroud removal - in car 912
Just going over the engine for leaks and adjustments and I could not remove the shroud to replace the oil cooler seals. Is it possible to remove the shroud with the engine in car or does the motor have to be dropped?
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 07-29-2006, 05:53 AM
C. Clark's Avatar
Porsche Crest
One could probably lower the engine by unbolting the rear motor mounts and lowering the engine to remove the shroud / Dog-House, but it is so easy and more efficient to remove the engine. I have complete engine removal details posted by another if you need them. They work very well for me.If you need them e-mail me.
Chas.
356
912
Thank you, Your Welcome! and Best of Luck....
Chas.
356912911
Old 07-29-2006, 08:06 AM
earlr85944's Avatar
excellent, thanks.
BTW, if I remove the motor, is it a drop in replacement to use a VW type 4 in the meantime while im working on the porsche engine?
83 944....bye bye
Old 07-29-2006, 09:31 AM
C. Clark's Avatar
No, I've never done it but I understand installing a type 4 is a little involved. This fellow has it figured out though, http://www.aircooledtechnology.com/store/
good luck,
Chas.
356
912
Chas.
356912911
Old 07-29-2006, 04:51 PM
