Stale Gas
I'm ready to start up the engine in my 1977 911S after doing a major clean-up to get rid of the oil leaks or at least be able to see where the oil is coming from. I made a mistake right at the beginning as I should have dumped some gas stabilizer in the tank and run it through the engine before I removed it from the car. Now I am worried, after 3 months, about starting the car on stale gas. Is there a simple way of draining the tank so I can add fresh fuel or is there some other action I should take before I try to start the engine. I did not rebuild the engine, just replaced gaskets, seals, and cleaned things up. Hope someone has some good advice. Thanks for the help.
assuming your 911 is like my 356...
disconnect the fuel line from where it goes into the fuel pump (or down under if that is easier to reach), then use a primer bulb type pump, like an outboard motor uses, and just pump the gas up and out and into a container. Then run it thru your lawn mower.
“IN MY EXPERIENCE, SUSAN, WITHIN THEIR HEADS TOO MANY HUMANS SPEND A LOT OF TIME IN THE MIDDLE OF WARS THAT HAPPENED CENTURIES AGO.” |
911's have a plug in the tank at the bottom 3 months is nothing I have stored my 912 longer..
I just don't get the American idea of fresh and stale gas.. if it's 10 years old yep it's stale.. if it's 1 year old run it. might not be as good but it will run..
Too many cars too little time.. |
"I just don't get the American idea of fresh and stale gas.."
we're a new country - we like things fresh. not to mention, when we think stale, we think lowered octane, which is not especially good for a high compression motor. with 3 month old gas, I'd just add 2 or 3 gallons of premium and go for it. |
