Hi, does anyone have any info on how to remove a stuck shifter lock cylinder. (It has been removed from the shifter housing) I was cleaning the lock and partially removed the cylinder with the key and three detents popped out. I was able to reinsert the cylinder, but I cannot turn the cylinder anymore or remove it to replace the detents. Help!
I did tht same thing some yers ago. All I can remember is that I kept playing with the pins until I got them in the right order and it worked. Sorry, it is not much help, but at least a been there. You can get it. I rememeber looking at the key and moing the pins to match the key/
___________________ Steve- 62 356 S90 Sunroof-sold 11/16 ![]() 73 911 No longer Targa-3.2L Running GT4 88 Carrera G50 sold 2019 2015 Cayman GTS |
