Questions about Knecht Air Filters
Hi everyone,
I now have a set of Solex carbs on my 912. I also have the Knecht wire mesh air filters. Here are my questions: Are these Knecht filters good enough? Should I use some kind of oil to increase the filtering capabilities of the Knecht air filters? If so, what kind of oil? I would like to get either a pair of the nylon socks or pre-filters, that VW sand draggers and dune buggies use, or a pair of the green foam pre-filters. Does anyone have any experience with those? I had Webers with K & N filters before, and that's why I have all of these questions about the Knecht air filters. Thank you! EZMiles
1967 912 1986 911 Carrera 1999 Exploder 1999 Honda Accord EX V6 1959 Farmall Cub 1941 Farmall Model B |
As a friend says, "Knecht air filters keep the rocks out, that said they are period correct. ************* has KN replacements as does Pelican I would imagine, classicandspeedparts.com is a good place and mainelycustombydesign.com/ has the high end custom setups, they look really nice.
Chas. 356 912
Thank you, Your Welcome! and Best of Luck.... Chas. 356912911 Last edited by C. Clark; 10-23-2006 at 04:59 PM.. |
