Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
earlr85944's Avatar
1968 912 jug hone?
I just honed my factory jugs to clean them up and changed the rings because 1 ring was cracked (that explained the low compression on 1 side. Now: did I damage the jug as it seems from reading on the net that these are all alum jugs?
83 944....bye bye
85.5 euro spec 944, 5sp (she's gone....
74 914...hasta LA Vista baby
87 924s....don't let the door hit ya
68 912.......see ya!
Old 11-20-2006, 10:27 AM
Steve F's Avatar
What you have is a alum finned sleeve bonded/pressed over a steel liner. I did the same thing to mine and just haven't run it yet,but with fresh rings you are correct in honing other wise the rings would never seat.
Cheers,Steve
1981 911SC Targa-1966 912 -1989 Alfa Spider Graduate
1967 912-1985 Toyota FJ60 Landcrusier
1985 Toyota SR5 4x4-1965 Baja Bug-1997-4Runner-4x4
1966 Bug stock-2004 Toyota Rav4-1989 XJ6 Jag
1975 914, 1965 Norton N15CS 750, 1975 Husqvarna 360 CR GP 1982 Honda 500 XLS
Old 11-21-2006, 09:30 AM
earlr85944's Avatar
thanks for the info, my info search was into very grey areas as performance parts listed my replacement jugs as all aluminum but a search on the net came up with porsche using nikasil treatment from 1970 and up. Anyway its great that I didnt do damage as there are other areas that need attention.
83 944....bye bye
Old 11-21-2006, 03:55 PM
912UK's Avatar
I rehomed my 356 ones it's in the factory book you can do it and there is tollerances to work towards stay inside these and your sorted..
Too many cars too little time..
Old 12-03-2006, 03:54 AM
earlr85944's Avatar
Thanks, I did find out they are steel sleeve with alum fins, ok to hone with the stones like we did.
Regards,
RS
83 944....bye bye
Old 12-03-2006, 06:27 PM
