Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
Atlantic07's Avatar
oil in 356 cylinder
This might be the problem:
one of the plugs showes oil (I think it is - it's a little wet and thick black stuff on the plug). I know I should have checked it first. Well, the funny thing is, that the cylinder fires, but I guess accellerating is a problem, because more oil gets sucked in (mmh - does this point to the valves rather than the cylinder?)
Interesting enough the cylinder still has compression (91psi - or is this nothing).
Is there any thread on taking the heads off and
- replacing head gaskets
- changing valve guides and valve stem seals
- piston rings
I hate this situation, but how hard can it possibly be?
Here is my shopping list:
- Valve cover gaskets
- Valve guides
- Valve stem seals
- Engine cylinder head gasket set
- Piston ring set
Would be nice if it weren't the rings! Never done this, but a friend of mine is a mechanic and might help.
Thx everyone.
1959 356 A Super
1961 Chevy Apache
1991 964 C2
Old 10-05-2007, 06:54 AM
Given the shopping list please realize there are valve cover but not head gaskets. A rich running car can give black gummy plugs. Is your oil consumption up? Are you spewing blue smoke? Jim
Old 10-22-2007, 04:39 PM
