Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
356 B crankshaft
I have a B Cabriolet that needs to have the crank refinished......which just might result in 3rd oversize bearings when finished.
My question is......... is 3rd oversize detrimental or bearing availability a problem OR can I have the crank refinished ( expertly welded up ) and refinished to Std size? The crank is otherwise in excellent condition ( no cracks ). Scat makes a new crank but not sure how much. Stoddard sells a new one for $1,200. What would you do? Thanks for any insight. Jeff
Old 01-08-2008, 12:26 PM
over 400 reviews and NO opinions?? Jeff
Old 01-09-2008, 08:47 AM
As most people will tell you go to 356talk. The 356 club. Those guys have been there done that.
63 356 So Called Outlaw
76 930
Old 01-09-2008, 09:39 AM
356racing's Avatar
Jeff,
You can go 3rd under on the mains for a street motor. I believe NLA has the bearings in stock...check first! I would not go to the expense of having a B crank built up and re-chromed.
Best,
Nick
Old 01-11-2008, 12:02 PM
I`ve also heard of steel and aluminum bearings........any thoughts as to which are better??
Thanks for your replies ! Jeff
Old 01-11-2008, 01:15 PM
