Sloppy Shifter
After a year of restoration on my 65 coupe, I'm starting to address some minor issues. My shifting pattern is all over the place. When I shift into third ,I almost hit my knuckles on the dash. Does anyone make a short shifter for these? If so are they difficult to install.
I would much appreciate any help. Dann
Dann 65' 356 SC Coupe 67' 912 04 911 Targa 67' Austin Healey 3000 |
I have never heard of a short shift kit for 356's.
When I had my 61 T5B, it had the same problem you described. I had all the shift linkage bushings replaced and it was like nite and day. The 356 drove fantastically like a different car. |
Acceleration Junkie
If you want to convert to a short shifter, remove the shift plate and arm, disassemble, cut the ball off the arm, add 1/4" length to the arm, re-attach the ball. (Note - The shaft is verrrrry hard steel. You'll need an abrasive cut-off wheel to cut it.) Shift throws will be reduced by approximately 30% as the stock shift travel from 1-2 and 3-4 is 3/4" at the transmission. Of course, you will need to fabricate a plate to go under your shift plate 1/4" thick to accommodate the longer shift rod. And you will probably lose the anti-theft reverse lock feature built into the stock shift plate because it won't fully engage/interfere with the shifter when engaged/locked. I know this works as I added 1" to the shift arm and fabricated a 1" plate to lift the shifter assembly to accommodate a 930 transaxle with its 1-1/2" shift shaft travel needs. |
356 short shifter kit--
http://www.willhoitautorestoration.com/shifter.php But I'd bet its the bushings worn.... |
