Go Back   Pelican Parts Forums > Porsche Forums > Porsche 356 Technical Forum
tb912's Avatar
Has anyone tried to do this?
Has anyone tried to fit Knecht air cleaners on weber carbs?
like these
they look like they'd fit.. maybe with a little bit of modification?
thanks for any input.
tanner
Old 07-27-2009, 06:53 PM
i put them on dellortos. i bought a spare set of bases, cut out the velocity stacks and drilled the mounting holes to fit. i got some short velocity stacks from cb performance to replace the oness that were cut out of the stock bases.
Old 07-27-2009, 08:05 PM
tb912's Avatar
I have a set of weber 40 Ida's I wonder if the base is the same size. I want the stock look without buying solexes..
Old 07-27-2009, 09:32 PM
webers and dells have the same bolt pattern (at the base and the top)
Old 07-28-2009, 04:32 AM
