356 final drive ratio option
I am looking to find out whether a higher final drive ratio (lower number than 4.375:1 is available for 1963 356 Cabriolet. The object is to reduce rpm for long distance highway cruising. About 10% would be perfect
Thanks Peter
gearhead
Try Jacques at Scott's Porsche. I think he has started making an 8:31 ring and pinion set. Otherwise the tradition solution is what we call a TG 4th, which you can get from either Tom Conway at Carquip or Vic Skirmants at 356 Enterprises.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
The single biggest improvement I made in the 20 years I've owned the 356 is the Skirmants tallest 4th.
63 356 So Called Outlaw 76 930 |
Thanks for taking the time to discuss this, I feel strongly about it and love learning more on this topic. If possible, as you gain expertise, would you mind updating your blog with more information? It is extremely helpful for me.
belt buckles belt Buckle Wholesale Zippo Cigarette lighters Metal Glass Smoking Pipes Belt Buckles
<a href="http://www.PaylessBuckles.com">belt buckles</a> <a href="http://www.PaylessBuckles.com">belt Buckle</a> <a href="http://www.Paylesslighters.com">Wholesale Zippo Cigarette lighters</a> Last edited by Phonixexn; 01-21-2012 at 09:16 AM.. |
![]() ![]() ![]() That last one matches up to the top pic with the gps s. This was on the ET highway keeping up with some Banzai early 911's a couple of 997's and a new Turbo.
63 356 So Called Outlaw 76 930 Last edited by Les Paul; 01-22-2012 at 05:58 PM.. |
Thank you all for your kind help. Will follow up with the options advised.
Peter :-) |
I cant seem to find an email address for Jacques at Scott's Porsche, Can anyone help?
Cheers Peter petermfaulkner@gmail.com |
gearhead
I don't have one, but a google search will give you his phone number.
Thanks Les
I have already made contact with 356 Enterprises, who do the alternative 3 rd and 4th gears. Scotts was suggested as doing a higher ratio final drive, still looking for a web link or email address Thanks Peter |
i checked this a few years ago with a 356 transmission guy - i believe he told me the 8:31 simply wouldn't fit in the 356 tranny case, and that's why it was never an option - hope this helps - brad in seattle
BBK ESQ '73.5 911 T/SC '76 914 "S" (from original owner) '62 356 T-6 Hardtop 62 OutlawR - porsche collection complete! '66 mercedes W111 euro s/r coupe - "silence is the sound of discretion!" |
