356C brake master cyliner removal
My brake master is froze from age and I need to remove it but wanted to know what is the best way to remove the hard line that is connected to the center that goes to the brake fluid reservoir that is mounted under the hood. Car hasn't run in over 10 years and will need some advice later down the road to get the engine fired up again after a long sit without breaking anything. Thanks for the help.
I have a B but went to a dual master. As I always tell the new guys with questions join the 356 registry. You'll get an answer in 5 minutes. And with your dues you get a very cool magazine too.
Be sure to use a line wrench. And soak it in penetrant a few times before you start. This will help the fitting spin on the line and avoid twisting your metal line to oblivion.
- Matt
http://www.unobtanium-inc.com 356 Registry 17369 Early 911S Registry 912 Registry, PCA |
