Hitting the brakes kills the car
I have a '57 Speedster. So, when I hit the brakes the coil voltage goes from 6v to 0v and comes back when you let the pedal back up. I have been looking all over for a wiring diagram with no luck. My fuse cover does not have the paper fuse chart any more so, I don't know what is what. I wouldn't think the ignition is on the same circuit as the brake lights?
So, my questions are thus: -Where can I get a good wiring diagram -Where can I get a fuse diagram -Are the brake lights on the same circuit as the ignition? I have a Haynes like paper manual on the way from Amazon, but I don't know if it has the wiring diagram. Any help would be much appreciated. |
Joe Leoni makes wonderful color wiring diagrams, laminated pages, very well done.
Wiring is correct DIN color coded. Switch Saving Starter relays (SSr)  The SSr improves starting efficiency by energizing the starter solenoid directly from the battery, prolonging the life of the expensive Ignition/Starter Switch by carrying a co |
The Haynes manual has a wiring diagram. It sounds like you have a short in the brake light/turn signal system. It is shorting the entire system. This is serious.
