Decoding VIN and Production Numbers
I have read the forums on decoding VIN and production numbers. As stated they may or may not match. However should the model numbers match on both. The forth number on my VIN is four indicating 1974 but the third production number is 0 which I assume means 1970. This car was delivered to Japan and later imported to Australia for road use.
Hope someone can clarify
Cheers Kevin
Old 05-06-2016, 09:37 PM
Discseven's Avatar
Kevin... welcome to forum. Here's the online resource to help you sort out your VIN.
https://www.stuttcars.com/technical/vin-decoder/
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-07-2016, 06:51 AM
Burn the fire.
Brando's Avatar
For Porsche to get an accurate VIN decode you need the following:
  • VIN
  • Model Code
  • Transmission Code
  • Trim Code
You can also use services like the NHTSA Product Information Portal: NHTSA Product Information Catalog and Vehicle Listing
My dev team uses this extensively to cross-reference vehicle specs from our inventory suppliers. Information outside of the US is limited, though.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 05-07-2016, 09:29 AM
djpateman's Avatar
Kevin, PM me with the numbers you have, and I will try and sort it out. I have done a fair study of production numbers, so it should be straightforward.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 05-07-2016, 02:32 PM
Vin number 911= model, 4= year made, 1= G- body, 1= Targa, the last 4 are the serial numbers, but don't quote me
Old 05-24-2023, 02:06 PM
