Broke down
A friend is loosing spark in the middle of no where on a 3.0
He changed the CD box and things are the same. Going to a FLAPS store what coil is compatable with the bosch CD to replace the Bosch coil. TIA BRUCE |
ROW '78 911 Targa
Most GM or other HEI coils should work to get him home.
MSD Blaster II if they have one.
I would rather be driving
Green signal wire from distributor to CDI is likely culprit. If its brown and brittle it likely has internal wire cracks. A CDI or coil will not fix the problem.
Where is his location?
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Louisiana out back
Bruce |
Hilbilly Deluxe
MSD High Vibration Blaster II is a direct replacement, but the failure mode doesn't sound like Coil.
Assuming when you say "losing spark" you mean it is intermittent. |
/ˈpɔrʃə/ PORSH-ə Fan
If he’s near Lafayette he can try out parts off my ‘82.
1984 ROW Carrera Sunroof Coupe Schieferblau 1982 US SC Targa Moosgrun 1977 US 911S Sunroof Coupe - SOLD |
If he is coming through TX/Austin on his way West then Let me know.
He got home. I think the shielded wire has defected again
Thanks for the input Bruce |
