RedCars
Gauge lights?
Hello folks. Just purchased an 84 Cabriolet and I'm trying to work out all the little electrical bugs. Are the light bulbs in the dash gauges replaceable? Can I get to them without removing the dash (in other words,without removing the windshield)?
Searched the forum but couldn't find anything. Thanks guys! Just replaced the alternator today. I couldn't have done it without the tech info center. |
The guages are just held in by the rubber that surrounds them.
Use a putty knife or a padded screwdriver to pry them out. The bulbs are pressed into the back and need to be pryed up (under the metal part not the plastic)
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
RedCars
Thanks Pete! Now if I could just figure out where the antifreeze goes......
84 911 Cabrio 81 Corvette, 01 Ferrari 360 Modena 94 Dodge Viper R/T10 09 Honda CBR1000RR, 05 Gold Wing 98 Honda Valkyrie ...... All RED ....of course |
You do not have to take the windshield out to replace the bulbs. Last time I did it was on the '69 but I dont think the '84 would be much, if any, different. Go in from behind, hehe, unbolt the instrument bezel and you can replace the bulbs. Might have to take some of the a/c crap out to reach, though.
Joe Riley IV 1984 3.2 Carrera Targa |
The instruments come out very easily. The bulb sockets pull out of the back of the instrument. I would replace all the bulbs. I got them from our site sponsor. The gauge illumination are all the same. In my 73 the instruments were a bit dull. Replacing even the working bulbs makes a big difference. Those old bulbs darken and get weaker with age.
The Alternator light is specials and make sure you the right one. It is part of the alternator charging circuit as well as being and idicator. Don't run without it. The high beam indicator and the low fuel light can be replaced with LEDs. Makes them a lot brighter. you can't just plug LEDs into the gauge illumination. This is an easy and great do it yourself project that gives great results. You should buy Wayne/' book 101 PROJECTS FOR YOUR PORSCHE 911. Covers this and 100 more things!!!
RGruppe #79 '73 Carrera RS spec 2.7 MFI 00 Saab 95 Aero wagon stick 01 Saab 95 Aero wagon auto 03 Boxster 90 Chevy PU Prerunner....1990 |
Pete, arent they held in by a bolt from behind that holds them to a mounting bracket?
John W
Start with the clock, once you get that out you can reach behind and push the others out, besides if you're going break a gauge what better one to break. I had a tough time getting them out the first time but I used some sil-glyde to lub the rubber before putting them back and the next time it came out a whole lot easier.
----------------------------------- John 89 3.2 Targa 123k miles |
3.4 Bigger is better
My gauges didn't want to come out by pulling on them and I didn't want to damage the dash or the trim bezel. Open up the trunk and use a golf club (turn it around and use the grip end) to start pushing the gauge out until you and get a holds of it and pull it the rest of the way out
Michael 88 911 Diamond Blue CE Carrera 3.4 HC3.4 member 2020 Honda Passport |
Weekend Mechanic
There are a couple of other options for better illumination on your dash gauges. There are LED bulbs that are a direct plug in replacement for the standard incandescent bulbs. Or, if you're feeling particularly adventurous, you can try the electroluminescent wire lighting upgrade. I'm planning to do a mix of both upgrades on my gauges in the next couple of weeks.
You can use the advanced search in the 911 tech forum for detailed threads on both of these upgrades. Take care and post some pics of your new toy! J
86 911 Carrera Targa
gauge bulbs
Take you time, don't force anything and you will be fine. It's a good idea to mark wires (tape or diagram/drawing) if you are taking more than one gauge at a time. And I think Pete commented to the fact>replace all of them at the same time. Here to bright nights, as bright a any early cars gauges are!
Art |
a.k.a. G-man
I always dread removing the gauges because of the risk of damaging the dash or the gauges. Thanks for the 411!
Сидеть, ложь, Переворачиваться |
+1 John W....clock first then the rest are really easy; be careful with the tach though, you'll need to angle it down towards the steering column to get it out enough to change the bulb....I just did mine and it makes a nice difference.
Neil
Neil 1987 Carrera, Grand Prix White, 2009 Carrera C4S, Meteor Grey Metallic (X) [B] 2011 BMW X5[B] 'Success is not final, failure is not fatal. It is the courage to continue that counts' |
Only on the two liter cars Joe! Be EXTREMELY careful pulling the gauges out-- make sure the battery is disconnected when you do this. There's a good chance the original wires have chafed or shorted over the years- the gauge illumination circuit (black wire with blue stripe) is unfused, and can easily short to the body sheetmetal or the brown ground wires, causing an electrical fire! Ask me know I know. . .
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
I have an '87 911. Purchased instrument bulbs from dealer last year. Got around to pulling gauges. Bulbs purchased have a metal base and push/twist in. My instrument bulbs are in a plastic housing. Pulled one bulb out of it's housing and it's glass with electrodes.
Did search and found: Porsche 911 & Carrera Lights and Lenses - Page 10 900.631.132.90 m97 900.631.102.90 m44 These 2 part numbers are the ones you will need for your dash lights. __________________ 1981 911SC Euro Pacific Blue Wayne The link is probably outdated and searching the electrical section and the P/N's shown above didn't yield any results. Does anybody know the correct P/N for this style of instrument bulb? Bulb markings: OS 12/1,2.
After reading this thread I pulled mine too, moved my speedo a little so I could see 70mph. Not to hijack, but thanks for setting me straight about the post two liters cars!!
I used this link
Pelican Technical Article: Brighter Instrument Upgrade To replace my bulbs with these. Pelican Parts - Product Information: 900-631-102-90-M44 They gave me a little more light, but not enough. I would love to hear more about the LCD direct replacements.
Kipp 1987 Black 911 3.2 Carrera Coupe 1999 Green Mazda MX5 (SOLD) |
Weekend Mechanic
Check out these 2 threads for more info on LED direct replacements and Electroluminescent wire. The EL wire looks like it gives better results but it is a bit more work than the LED bulbs. I ended up ordering LED bulbs before learning about the EL wire and in the end ordered EL wire as well. I hope to do my gauges in the next couple of weeks.
http://forums.pelicanparts.com/porsche-911-technical-forum/358935-white-led-dash-gauge-illumination-photos.html?highlight=led+gauge http://forums.pelicanparts.com/porsche-911-technical-forum/469224-el-wire-alternative-oem-led-lights-gauges.html?highlight=led+gauge
I had a bad socket on one of the four hvac lights. One got hot at one time and would no longer hold a stock light. I pulled out the harness from behind and replace all four lights with L.E.Ds and made a new harness to hold them. Then plugged back into the hvac unit and looked great. Found the L.E.D source from a former post here; Superbrightled.com, I belive.
-Bill 1979 911 SC Targa |
Go Speedracer, go!
1981 SC ROW Coupe |
