One leak left! Please help me identify it!!
Hi Pelican,
I have one leak left on my 76 911S Targa. It seems to be coming from between the right side chain tensioner and valve cover?
If anyone can tell me where this is coming from I will give you a virtual high five!
Thanks!
Old 10-26-2018, 09:08 AM
proporsche's Avatar
Hi that is a lot of oil leaking.What did you do on the front leak if any work was done?
This could be your camshaft cover o ring or the 3angle gasket.Unles you just work on it?
The other culprit is on your camshaftoil line fitting to the camshaft housing the fitting it self is loose.
Right here is a alu.seal ..
1985 911 with original 502 191 miles...808 198 km
Old 10-26-2018, 09:21 AM
I'm hoping its the cam shaft oil line now you say it. I'll be with the car this weekend so will inspect again... THANK YOU
Old 10-26-2018, 09:38 AM
proporsche's Avatar
Hi not the oil line but the fitting which is attached to the camshaft housing.There is a aluminium seal.The fitting could be loose.Black arrow points right to the spot...
Ivan
Old 10-26-2018, 09:54 AM
Registered Minimalist
75 911s's Avatar
Yeah that's a lot. If it's not the cam feed line, then another suspect is the back of the chain box cover. If you get underneath with a light and look up between #4 cylinder and the chain box you can see if the jb weld type stuff from the factory has worn away and the tensioner shaft is poking out the back. That kind of oil loss means a major hole like that.
It also sounds like you have an exhaust leak.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 10-26-2018, 10:05 AM
