One leak left! Please help me identify it!!
Hi Pelican,
I have one leak left on my 76 911S Targa. It seems to be coming from between the right side chain tensioner and valve cover? If anyone can tell me where this is coming from I will give you a virtual high five! Thanks! |
Hi that is a lot of oil leaking.What did you do on the front leak if any work was done?
This could be your camshaft cover o ring or the 3angle gasket.Unles you just work on it? The other culprit is on your camshaftoil line fitting to the camshaft housing the fitting it self is loose. Right here is a alu.seal ..
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Hi not the oil line but the fitting which is attached to the camshaft housing.There is a aluminium seal.The fitting could be loose.Black arrow points right to the spot...
Ivan
Registered Minimalist
Yeah that's a lot. If it's not the cam feed line, then another suspect is the back of the chain box cover. If you get underneath with a light and look up between #4 cylinder and the chain box you can see if the jb weld type stuff from the factory has worn away and the tensioner shaft is poking out the back. That kind of oil loss means a major hole like that.
It also sounds like you have an exhaust leak.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
