Unhappy 1985 Porsche 911 Targa Carrera
The car is running fine but the gas tank is almost empty. I stopped at the gas station to fill up. While waiting inline, I turned off the engine. I turned on the engine again, it won't start. It is cranking but it seam like not enough fuel to start the engine. Pushed the car to the pump and fill up the tank. Started the engine again, iit won't start, only heard the cranking. End up to tow back home. At home, check the DME relay is fine. Car still won't start. I am thinking to remove and test the fuel pump. I am looking for a procedure how to remove the fuel pump. Any suggests to trouble shooting engine won't start issue. Thanks
Old 01-30-2019, 11:53 AM
Red Line Service
Marc Bixen's Avatar
Where are you located? Is it raining, or did you just wash the car? 3.2's are very sensitive to moisture if the distributor cap is old. (over 45,000 miles) Pull the cap, check it, dry it, try to start again. If that works, replace the cap. Also, if the DME relay is more than 10 years old, swap it out also.
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 01-30-2019, 12:16 PM
Still here
pmax's Avatar
JB,
How did you conclude the DME relay's fine ?
Old 01-30-2019, 12:33 PM
Check resistance of speed and reference sensors per the SM in the engine bay - they can go out like a light bulb and your can will not start
crude rudy
'84 cab
'14 ZX-14R
Old 01-30-2019, 05:21 PM
kevbo's Avatar
Fuel pump right behind tank underneath. Just need to remove protective shield to.access.
Kevin
1986 Carrera Targa
Old 01-30-2019, 07:12 PM
Marc, Thanks for the tip about the distributor cap and moisture. I rarely wash mine but rather use a spray cleaner. But recently I did and after starting it and shutting down the engine would crank but not start. Suspect verified by your post. An hour later tried again and the old girl fired right up. Time to change the cap though. BTW in the past 10 years its only seen rain once.
1987 Guards Red Targa, cams, exhaust, MFI intake, lowered, 7 and 8's, 200,000 plus miles of smiles
Old 01-30-2019, 09:55 PM
twistoffat's Avatar
When I hear the tank was nearly empty I keep thinking about dirt getting into the lines
Think you may need to clean the tank and replace the filter
Old 01-31-2019, 03:12 AM
spoke's Avatar
I agree.
I fill up when the gauge goes to 1/2 tank. My 930 sucks down too much fuel to let it get low.
Find Spoke's LED Products:
www.spokeworksled.com
Old 01-31-2019, 04:12 AM
85911's Avatar
"Check resistance of speed and reference sensors per the SM in the engine bay - they can go out like a light bulb and your can will not start"
What does SM stand for?
1985 911 Carrera Targa, 2011 911 Carrera S 997.2, 1951 Harley Davidson Panhead Chopper, 1957 Harley Davidson Panhead- stock, 1972 Yamaha 250 DT-1(sold), 1959 Austin Healey (Bug Eye) Sprite- sold, 1959 Austin Healey (Bug Eye) Sprite- sold, 1960 Austin Healey (Bug Eye) Sprite- sold
Old 01-31-2019, 07:58 AM
service manual
crude rudy
'84 cab
'14 ZX-14R
Old 01-31-2019, 08:03 AM
A Bentley manual goes a long way towards keeping the tow trucks at bay.
Old 01-31-2019, 08:58 AM
proporsche's Avatar
when you say the tank was almost empty? Did you see the reserve light on ..or was it on for a while..?
Also check in your engine compartment these 3 plugs if by coincidence one of them is off..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 01-31-2019, 09:26 AM
Checked out
McLovin's Avatar
When you turn the car off, you create a bit of a heat sink on engine components, that can make marginal sensors not work right.
My guess is it is one of the three sensors proporsche posted (speed, reference and CHT sensors). Esp. the CHT.
I think the fact that it didn't start after you filled up the gas tank is not related to the no-start.
Old 01-31-2019, 01:51 PM
Checked out
McLovin's Avatar
I'd also check to make sure your battery connections are tight and clean, esp. the ground cable. And that the battery cable end crimps are solid and clean.
Old 01-31-2019, 01:53 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
To the original poster: it would be nice to have a title that is a little more descriptive. It will give you a lot of more focused answers quicker. That being said there are lots of 3.2 no-start threads here. Do a search and you will be surprised. They mostly fall into one of two categories. 1) "I had the same and it was that...." and 2) a more systematic approach:
The 3.2 engine is controlled by a DME. The two items that are notorious to fail are the DME relay (aka fuel pump relay) and the sensors that tell the DME the flywheel speed and position. Either can fail intermittently and either will cripple the car. The systematic approach is to check for power to the DME (ICV on top of engine vibrates with ignition ON. If not an alarm system or a bad ignition switch could be the issue. Next, the DME relay can temporarily be replaced by a jumper. Some suggest to carry a spare. If either makes the car run you found your issue. Next, it's down to some more diagnostics. The engine needs fuel and spark to run. There are three cases:
1. No fuel
2. No spark
3. No fuel AND no spark
Case 1
Spray starter fluid into the intake. If that makes it catch it's missing fuel (fuel pump, fuel filter, fuel pressure, or worst-case the DME or one of the injectors). It also tells you the FW sensors are good.
Case 2
Checking for spark is done easiest with a timing light or a spare spark plug. If spark is absent now it's either case 2 or case 3. To find out which you need a NOID light (eBay is your friend) or an LED test light and check for fuel signals on the injectors. If you confirm fuel signals are present but only spark is missing this points towards the ignition coil, the distributor or the DME itself. This is a classic failure mode of the DME.
Case 3
If spark and fuel are missing this points towards one of the FW sensors. If one of them is bad both fuel and spark pulses will be missing. The sensors can be ohmed out for a quick check but even if they check out O.K. that way they can still be the culprit. Lot's of cases here. If the sensors are good it could be the DME (sometimes the decoder for the flywheel sensors fails).
The other sensors would cause poor running but not be responsible for a complete non-start. So table that for the time being.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-31-2019, 02:22 PM
Originally Posted by pmax View Post
JB,
I pulled out the DME and tested. I also heard the click when it energized.
Old 02-04-2019, 10:38 AM
Ivan
No, the reserve light wasn't on. Will try to test the sensors. Thanks
Old 02-04-2019, 10:45 AM
DME relay failure can be pretty transient and the cold soldier joints that are generally the failure source can work just fine with a high current test but fail when dealing with the real world low current -- I'd recommend picking up a spare and confirming that substituting in the spare doesn't change things
Old 02-04-2019, 10:51 AM
@proporsche. I found the white plug is broken. Do you know the part number of this plug and how do I order it. Thanks for younhelp
Old 06-08-2019, 07:07 PM
Brew Master
cabmandone's Avatar
FWIW, I bench tested a DME relay once and SWORE it was good..... it ended up being the reason my car wouldn't start. If you don't have one, get a spare... you'll need it at some point.
As I understand it you can hear the relay click but there are solder joints that fail so even if the contact closes, the circuit might be open.
Nick
Old 06-09-2019, 05:48 AM
