Fuel tank barb thread size?
Hi all. I'm converting my 1968 (912) to EFI and need to plumb a return line to the tank for the high pressure fuel system.
The tank has three holes available. One is a drain plug. Only one of the larger holes is used (as an outlet) at the moment.
Does anyone know the thread size and pitch of these two larger holes?
I'd like to investigate running the return on a 45-degree banjo to give me a bit of space back there.
Old 02-07-2021, 02:31 PM
Dropped the fuel and removed the plug to answer my own question in case anyone ever searches for this.
It's 22mm x 1.5mm
The smaller plug is 14mm diameter. I didn't check the pitch.
Old 02-13-2021, 07:31 PM
