915 gearbox rant
Question here: am I the only one that hates the 915 gearbox with a passion? I have one in my '84 Carrera. Now before you say "oh, you just didn't set it up right", let me list the things done: Jwest shift tower, Wevo short shift kit, Wevo coupling, new OEM synchros on 1st and 2nd, fresh Kendall oil, relatively fresh shifter bushings, recent coupling adjustment. So I went the whole 9 yards. Shifts way better than I got but still far from good.
Now, I maybe spoiled by the modern gearboxes since I've owned nothing but manuals since 1998 including multiple NA Miatas, Integra GS-R, WRX and even a '72 Beetle. The latter is what got me into Porsches. The 4-speed box on the Beetle is a lot easier to live with. It doesn't require rev matching and only minor issue has been a bit of a grind on the first on a standstill but I can live with that. I won't mention others because the Miata and Integra boxes are in a whole different league compared to the 915. They're not even the same sport really. The only one that was just as crappy was the 901 in the '75 914 I owned for a few months a few years back. Enter 915. That thing just seems to get into 2nd gear whenever it feels like it. Rev matching or not, even with a new synchro I can't get it in some of the time when not upshifting sequentially. 3-4-5 gears are somewhat acceptable providing some rev matching is happening but the first two are absolute horror. Even the first gear won't always engage despite a new synchro prompting my getting the horn from behind more than once. I haven't driven a G50 car but I imagine it's a lot better. Have driven a 993TT and obviously that gearbox was working fine although the clutch was admittedly rather weird. Still it wasn't too bad and I learned to drive it smoothly quickly enough. So I'm curious, any other owners who dislike 915 or is it just me? Last edited by Synchromesh; 05-19-2019 at 11:22 AM.. |
Sounds like your transmission is off some how. Have you driven other 915’s for comparison?
I’ve never experienced the 2 nd gear issue you are describing, Ive owned 2 sc’s and 2 Carreras.The most typical nuance is that shifting into 1st or reverse sometimes requires slow and deliberate action, aside from that , the 915 really isn’t that hard to use. |
I think it's going to depend on your usage. I enjoyed my 915 on the weekends but hated it Monday thru Friday. In my opinion, the 915 adds something special when you are at full tilt but is otherwise quirky. That being said I sold my 78' and kept my 87'. I do, however, miss the 915.
I have a similar setup for my 915 (all the Wevo stuff, Kendal, DIY rebuilt w/new synchro's...) and mine shifts well through all the gears - as good as a 915 can be.
Granted, it doesn't shift like a modern trans - but I can grab 2nd under hard acceleration without hesitation, and I can drop it down into 1st at 15-20 mph without worry of grinding or hesitation. Who did your trans / synchro replacement - was the 1-2 shift sleeve replaced along with the synchro hubs & rings (i.e. all 1-2 synchro components or partial)? Gordo
Don "Gordo" Gordon '83 911SC Targa Last edited by Gordo2; 05-19-2019 at 05:39 AM.. |
There is a legend that if the lay shaft isn't absolutely straight, the car won't shift correctly. And then there is clutch drag and pilot bearing drag that can cause havoc. And Swepco oil makes the shift to second a real drag in colder climates. IMO, it makes the shift to second a really deliberate process on any car I have run it in.
I don't know if you have a problem or not, but I'd look at changing the fluid first. You can always tell if there is Swepco in the box. The sweetest 915s are very sweet, and talk to your fingertips. Some are only going to respond to a rebuild by a real persnickety expert, or so I'm told. Having driven some over the years, for every doggy one there is another that is a gem, and a bunch of average ones. But I never drove even a balky one wouldn't go into gear if you drive them the way they want to be driven. |
Exactly..."talk to your finger tips" Its technology that's 35 years old, regardless of your "upgrades" its not going to feel like anything from 1998.
1984 Carrera Targa |
A short shift, a partial rebuild and a linkage adjustment that's out of wack. What could go wrong?
I'm with Gordo...bet it needs the 1-2 slider. Wish you could drive mine or another nice 915 for reference.....mine was horrible until a proper, competent shop repaired it, which included synchros AND said slider. That said, it'll never be like a Miata, Civic, S2000 etc. and the comparison in kinda meaningless. John
He he.
Ass-engine Nazi slot car -- PJ O'Rourke |
Your 915 is not working properly. The symptoms you describe do not describe how a properly working 915 gearbox works. Try a rebuild by a reputable shop and it will not behave like that.
Grappler
If you recently rebuilt your 915 it will be quite tight for some time. It takes a while especially if you only drive it on the weekends but once it loosens up it's a nice gearbox. Shifting into 2nd will be significantly improved but never perfect. Its just one of the characteristics of that gearbox and part of what makes driving an early 911 unique. BTW, the heat and A/C suck too. 8-)
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
gearhead
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
There may be some issues with your 915 but you are not wrong that it is very old technology and even when "perfect" it isn't a Miata or a BMW 3 series or any "good" shifting trans.
VW bugs and 901s use the same syncro technology and basic architecture but they shift better because the gears are smaller and lighter, use smaller clutch disks and the syncros don't have to work as hard. Close ratio 915s shift much better as well as using a non sprung "puck" clutch disk as this decreased the inertia that the input shaft has. Not something you really want in a pure street car though. I found with my 915 with stock gearing I could downshift faster that then syncro if I double clutched the downshifts but that takes a lot of time to master and is really only for on the limit driving you can't or at least shouldn't do on the street. Learning to work the gearbox is part of the 911 experience........ or you buy a G50 car and put in a light weight clutch and flywheel and it shifts like an '80s BMW......... I am in the process of doing this, it's a big project. |
Bugs don't have 901/915 style syncros.
Under the radar
I have a warmed up '67 Bug, in which I have a built (by me) heavy duty custom trans. I also have a modded, by me, 915 in my 911. The only thing the VW box can do that the 915 can't is to speed shift from first to second gear. In normal driving not a world of difference. As Matt says, and others have mentioned, there are subtle differences in the parts of these 915s that can make a huge difference in shifting. You should find a 911 with a good shifting 915 to compare. It may be that your rebuild needs to be rebuilt.
My car has a rebuilt tranny to begin with, it was replaced about 10-12 years ago by a local shop. Found it in records. I only put in the OEM synchros because it was a sub job of rebuilding the engine. We did check the other parts and they looked good so I didn't put anything else in aside from the Wevo kit. Quote:
Still here
But, yeah, I hear you, for "spirited" street driving in stop and go commute traffic, the 915 just doesn't cut it, unless you like holding up traffic at the lights ! |
https://www.youtube.com/watch?v=Ns6nEPXHrFo Close ratios and a really light clutch disk gets you to here https://www.youtube.com/watch?v=xAYVTTIgBto But you need a G50, close ratios, and a multi disk small diameter clutch if you want truly superb fast shifting. https://www.youtube.com/watch?v=zyM-egecTlw |
AutoBahned
the OP may not be a "Porsche Person"
get the box checked out - if it's good then wuss out and buy a G50 car |
Caveman Hammer Mechanic
That being said, you cant just throw parts at them and think its gonna be more *****en, by some percentage with every part added. My car is also a 1984 Carerra, and the trans shifts with very Teutonic precision, no grinding in any gear unless I do something stupid like not release the clutch all the way. I have a extended shifter, short shift kit, Stomski shift coupler, new bushings, Rebel Racing trans and engine mounts. I couldn't think of anything I would change, except for a Wevo shifter setup. I will also say with a rigidized shift linkage, a couple mm in coupler position or one spline left or right equals a huge change in shifting to include grinding and working poorly.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
