-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   engine build and paint endeavor (http://forums.pelicanparts.com/showthread.php?t=1030241)
mike sampsel 05-22-2019 11:16 AM
Well after the engine drop the CIS came off. This time it was quicker than when I pulled it with the engine in the car.
http://forums.pelicanparts.com/uploa...1558548808.jpg
Flat6pac 05-22-2019 11:34 AM
Save the 12mm nuts, hard to find.
Another 70s 3.0. Great
Bruce
mike sampsel 05-22-2019 12:44 PM
Aye, got all 12 of those beauties in their own little bag.
mike sampsel 05-22-2019 12:49 PM
Well I am going to save pictures of the Cold start and air meter plug. Since I miss labeled it but fixed it. Anyway ... cold start valve plug bluer and on the right of the photo. Tape on harness. The harness gives a clue too as to the directions the wires diverge.
http://forums.pelicanparts.com/uploa...1558554442.jpg
mike sampsel 05-23-2019 03:53 PM
Took off pp today and see the flywheel and clutch disk. New clutch is inthe plan. Does the Flywheel look okay?
http://forums.pelicanparts.com/uploa...1558651735.jpghttp://forums.pelicanparts.com/uploa...1558651888.jpg
ADDvanced 05-24-2019 06:42 AM
Looks good to me, even wear. I would scour it with 3m pads and clean it with brake clean.
mike sampsel 05-27-2019 12:56 PM
Thanks for the idea
mike sampsel 05-27-2019 01:01 PM
Tranny is in the truck bed. Going to get clean tomorrow. Hoist was needed for old me to place it the truck bed.http://forums.pelicanparts.com/uploa...1558987238.jpg
Bob Kontak 05-27-2019 01:33 PM
I hear you but for under $100 you could have that refaced.
Tap in a new main seal as well.
Took mine to a local machine shop. $65 ten years ago. Told this before but I said to the shop owner "You have to be careful because there is a step in there". He looked at me straight faced then a little grin appeared, like this ain't my first rodeo.
mike sampsel 05-28-2019 04:16 AM
Appreciate the input, I’ll be splitting the case (sometime this year :)). New main seal for sure. Will consider flywheel refaced too now.
mike sampsel 05-28-2019 07:12 AM
Well the after look is better, not quite spotless though.
Wonder if more cleaning is worthwhile?
Before in the link
https://forums.pelicanparts.com/porsche-911-technical-forum/1029960-engine-drop-photo.html
http://forums.pelicanparts.com/uploa...1559052584.jpg
mike sampsel 05-28-2019 04:35 PM
Progress, slow but some.
There is a crank under the flywheel. No sign of leaky main seal. Definitely easier to remove FW bolts with impact wrench.
http://forums.pelicanparts.com/uploa...1559086421.jpg
rwest 05-28-2019 05:15 PM
Before in the link
Cleaning it more will make for a better picture, but after going down a few dirty roads in the rain and it will look bad again. The temptation is so great to put effort into stuff like this, but it gets ugly fast and you can’t see it once installed.
mike sampsel 09-29-2019 05:06 AM
Well nearly complete with engine assembly. Coming off the stand and meeting the transmission next week. And it looks like I put my coil up higher than it was before.
Here’s a group of photos of some steps along the way.http://forums.pelicanparts.com/uploa...1569758557.jpg
911tracker85 09-29-2019 07:16 AM
great job...
I am waiting for my engine parts to come back from rebuild / machine shop.
