Liqui Moly Touring High Tech 20W50. See Data Sheet. with MoS2 added on top. |
I had a lower oil pressure and a VERY high oil consumption. I discussed with him and we agreed to try BP. Pressures were normal (about 10 psi/1000 rpm) and my oil consumption drastically improved. |
Thank you everyone! Going BP20W-50!
I've been drinking the Brad Penn koolaid myself for 12 years.
Much better way to go with these older engines? Liqui Moly 20W-50 My 3.2 at 107k miles never felt so smooth with "Liqui Moly 20W-50 Touring High Tech Motor Oil: - Tossed in 2 cans of Liqui Moly Anti-Friction Engine Treatment (shake the cans before putting in the oil) Just, smooth as silk.... Make the change; you will not regret it. Only issue is you have a hard time buying them in quarts! |
https://forum-liqui-moly.de/index.php/forum/motoroele/209-motoroel-fuer-oldtimer-v8 https://forum-liqui-moly.de/index.php/forum/motoroele/1580-zddp-anteil-lm-1440-formula-super-15w-40 Also explained here: https://nineelevenheaven.wordpress.com/oil-varieties-for-the-911-sc/ |
| All times are GMT -8. The time now is 02:38 PM. |
