-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   78 alternator replacement w Valeo wiring? (http://forums.pelicanparts.com/showthread.php?t=1031410)
911TerryT 06-05-2019 10:07 AM
Hello, I am Replacing a 78 alternator with a Valeo alternator. I have Read about the internal and external voltage regulator differences. I am Still confused if I go with Valeo internal regulator, what do I do With the black wire that is for external regulator? Also, what problems may I have With my gauges if I select the newer internal regulator. Thank you.
john walker's workshop 06-05-2019 10:23 AM
Just fold the black wire back and remove the old regulator. No need for the black wire. No difference in the gauges
911TerryT 06-06-2019 04:19 AM
Thank you for response. Does the alternator light in the gauges now become inactive with dead heading the black wire?
john walker's workshop 06-06-2019 04:47 AM
The light is in the blue wire circuit.
Targalid 06-06-2019 06:59 AM
Alternator shaft is a different diameter. The Valeo fan/alternator/pulley nut is 24 mm instead of the 22 you had.
john walker's workshop 06-06-2019 10:48 AM
Yeah, the cup washer hole probably needs to be enlarged to fit the new shaft. Die grinder or rat-tail.
carlvs 06-06-2019 11:51 AM
The SEV Marchal alternator on my 78SC ROW failed about two weeks ago. Replaced it with a
Brand: Bosch
Part Number: AL9341X
Item Condition: Remanufactured
Item Description: Alternator
Manufacturer Brand Description: Reman Alternator
Quantity Needed: 1;
Fitment Notes: Optional;70 A;
Cost $164.84 including shipping on eBay.
Works great, so far.
The nut was included now 24 mm wrench size instead of 22mm.
Used the existing external regulator.
Targalid 06-06-2019 03:34 PM
I enlarged the cup washer described by John Walker using a round file in a motel parking lot. I highly recommend the die grinder alternative in your own shop,
