Fabric covering - Targa roll bar window seal
Hi all,
The fabric covering on both sides of the rubber seal that the side windows glide up and down on has degraded. Is the fabric repairable or available separately? I had the Targa roof redone, all the seals done, so would rather avoid redoing this seal. I can't understand why the fabric has broken up so quickly (had thought it was an OE part). Redoing the part 91156509145 would be both expensive and might mess up the roof / door seal. It's a 3.2 1984 Targa. Any thoughts please?
This article might be of some help to you,
https://www.pelicanparts.com/techarticles/concours_corner/concours_corner-3.htm and you might be able to find fabric in a hobby store. Years ago, my seal was in infinitely worse shape than yours, so I bit the very large bullet and replaced the whole seal.
1958 356A - Sold to a rust collector 1978 924 - sold to a sewing machine repairman 1984 944 - meticulously maintained but everything except the drivetrain self-destroyed. Used in trade for my wife's MB 1988 Carrera 3.2 Targa - purchased in 1992 and still thriving. Boy, do I love this car |
The annoying thing is that I had that seal replaced already... Guess I'd better buy a new seal. |
If the actual rubber is intact, recover it. Sorry I can't remember the name of the material but the local upholstery supply know exactly what it was. The gluing was really easy. I'd recommend a heat guy to set the glue quickly.
Any idea how to find out what the fabric is? |
Just had to jog my feeble brain. It's called duck cloth. I like the cloth versus synthetic for looks.
With that amount of labor involved (I'm unlikely to attempt myself!), maybe teh new seal is best... Mike_Lettrich JP911, I'm confused as to what pieces you are referring to. Do you mean the fabric covering on the seals on the sides of the front of the Targa bar where the window seals, then extending upward and covering where the "prongs" of the Targa top insert into the Targa bar? |
If you can replace them, you can recover them. Way easier than it seems
Well I wish I'd seen this write up when I replaced the seal years ago. I think that 2-1/2 hours per side would be worth it versus 2-3 hours to remove, clean, and replace the whole seal, which at the time was a $350 part and now I see it goes for muchmore than that for a proper one.
I think I have an extra freshly recovered one if anybody needs it.
