This Way Up
I have used this - it's the harness mounting kit from Brey Krause that also functions as a mount for the seat belt receptacle. Worked well in my '89
https://www.bkauto.com/R_9005_Harness_Mounting_Kit_p/r-9005.htm |
1970 914-6 1988 911 1985 928S 1974 Triumph TR6 1974 Datsun 260Z |
Any updates on the seat belt situation?
Paul 1987 Carrera coupe |
Grease Monkee
Bumping an old thread as I am in the same bind..
Putting Recaro Speeds into my 86. Planted seat brackets. The belt receptacle mounting point hits the seat. Curious is anyone has found a solution for this. |
Going through this as well currently, putting Recaro LX's in an '85. Tried the BK mounts, didn't clear. Having a shop fab up something custom to make it work.
Mike '85 3.2C IG: @msmall90 | @zuffenphilly | @ruchlosrallye |
Grease Monkee
They wanna make an extra set?
86 911 Carrera Coupe 99 996 C2 Coupe (former) |
The 964/993RS models used this receptical braacket
![]() and some 3mm thick washers to keep things level at the other corners ![]() a GT3 bar has the same 3mm thickness at the ends if you want to use subs
Grease Monkee
Thanks Bill. Unfortunately Those brackets aren't really applicable to a Recaro Speed (not side mounted) and the RS bracket won't clear the side of the seat
Try #901.521.944.01
Used on my 73 with a Recaro LS Seat with a Grant sliding mechanism.
65 356SC Cab - 70 T Sunroof Coupe - 82 SC Targa - 86 Coupe - 87 Targa - all sold years ago 89 944S2 Daily Driver-Sold because...still thinking why. 73.5CIS Targa Shed Find -On the Road Again |
Grease Monkee
That might just work if I get the passenger side unit and flip it to face away from the seat back.
Thanks!
I'm good with tools.
I have used the "Planted" bracket twice with fantastic results. The identical Recaro's in my sister's 88 Targa and my current 72 build with Lemans style Classic Touring Seats. I stumbled on these brackets a while back and i'll never go back to fussing with other brackets and trying to adapt them to the mounting points in any 88 or older 911.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
Why not give the bracket a slight bend?
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car 77 BMW R100S 99 Ducati 996S 04 BMW R1150R |
Grease Monkee
Going to try that next
