Which oil should I use for my 3.2?
Will only drive it in spring/summer/fall, I drive in spirited manner but no tracking. Only drive it on the weekend so cost is less of an issue. Thank you in advance!
Jonas |
Vulnerari Praesidio
Valvoline VR1 20W-50
You could try the search function...
"Wisdom is knowing what to do next; virtue is doing it." - David Starr Jordan |
A high quality 20W-50 with a high level of ZDDP. Valvoline VR1, Penn Grade, Kendal Gt2 are are common recommendations.
While it can be overwhelming, read the many threads on the topic.
I run 15/50 Mobil 1 in my SC, mostly because it's so affordable at Walmart and has high ZDDP. I'd likely be just as well off running Delo or just about any other modern oil. We all obsess way too much on this. I do buy Mahle filters....don't go cheap on those. Best, John
Porsche A40 approved oils in 0w 40 M1 for me.
Brew Master
Can of worms opened.
Right now it has Castrol in it. I typically buy Havoline 20w50 but the place I normally get it was out. I have no preference to brand.
Nick |
there are several oils available that fit the bill If a particular oil company refuses to provide ZDDP levels I'd avoid their products Mobil is widely available and reasonably priced, here is the Mobil 2019 spec sheet, remember you are looking for 15w40 or 15w-50 and Phosphorus and Zinc levels in in the 1100 to 1300 ppm range, anything outside those values is not what was originally spec'f and the further out the worse for the motor longevity.
Looking at my Bentley, 20W-50 is recommended for 15 F to 100F+
SF became the spec in 1988 ZDDP for that and SE was ~1100/1400 generally these were non synthetic back in that era. Porsche latter codified it and specified mineral oil 15w-40, 20w-50 for temps mostly above 50F/10C synthetic oil 10w-40, 15w-40, 15w-50 for temps mostly above 50F/10C other specs for lower temps of course, This is all in the TSBs from the era
The first 3 years I owned this 3.2 I used Brad Penn 20W50 with an oil consumption of 1200miles/qt. Next I switched to Valvoline VR1 20W50 and consumption dropped to about 1750miles/qt. This year switching to Liqui Moly Touring High Tech 20W50 and having driven about 600 miles I do not see any appreciable oil usage, even though as miles build up it is natural to expect some oil consumption, but no doubt this reduction is notable. And the engine purrs beautifully!
I also use Liqui Moly MoS2, but I used that along with the previous oil brands.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl |
OCPO
This could get ugly. BP 15w40 but I tend to top off with BP 20w50.... please check this out. Many questions will be answered...
http://forums.pelicanparts.com/porsche-911-technical-forum/367300-ultimate-motor-oil-thread-why-we-hate-cj4-sm-oils.html
2018 X5 86 911 Targa 3.2 80 Mercedes 450SL 2006 530xi BillyBoat/H&R's....gone Last edited by Storage Man; 05-27-2019 at 06:38 AM.. |
FYI - here is one where there is a specific pitch on the website for use in air cooled Porsche engines. FWIW this product was recommended by a Porsche shop about 40 miles from Philly when the local PCA club held a meeting at the shop. I've been drinking the Brad Penn koolaid...so no direct experience with Joe Gibbs.
https://lnengineering.com/joe-gibbs-racing-dt50-full-synthetic-15w50-aircooled-engine-oil-12-quarts.html
74 911 3.2 |
I don’t know that I have ever read on here someone saying that their engine when apart was showing excessive wear and issues that pointed to use of inferior oil product selection.
If you keep it clean with appropriate change intervals and use proper weight with any API certified oil, I have to think you are going to be alright for a road car. |
The problems beagan back in the early 2000s when there was a switch in some oils to less than a 1000ppm ZDDP, it's now common is some oils to have 800ppm or less. Thes oils don't provide proper wear characteristics on the cam lobes. I know one fellow that trashed his 964 after just a year or so of using such oil. Use the right weight and right ZDDP content and the car will be happy, there are several very good oils out there and also some marginal ones. Just avoid the sub 1000 ppm ZDDP oils by doing your due diligence
Yes, reputable brand, good ZDDP, replace it more often than specified. And don't thrash the car when it's cold. This advice leads to a long and happy life for a 911 engine.
There are substitutes for ZDDP... In Germany no one uses Brad Penn or Valvoline...
Cars and Cappuccino
Like this soon-to-be-hitting-US-shelves Liqui-Moly Klassic https://www.liqui-moly.com/en/company/news/detail/news/classic-car-care-fountain-of-youth-for-your-favorite-1717-1.html
http://www.carsandcappuccino.com 1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits 1985 Prussian Blau M491 Targa 1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe 1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday) |
True but they are not available here at a reasonable price.
