7.0:1 > 11.3:1 > 7.0:1
Are LWB stub axles compatible with aluminum trailing arms.
I'm installing 1985ish Carrera aluminum trailing arms in place of the steel units in my 1970T. Can anyone confirm if the outer stub axle from the 1970 arms are compatible with the alum arms/wheel flange from 85? (Moving the 4 bolt 2 pin over in place of the 100mm 6 bolt)
Stub axle pic from the web
Yes.
Thanks for your feedback John. Appreciated.
Jim |
I would rather be driving
Yes.
I have done that on a few cars.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
