Super Moderator
Main bearing 72-3429 0.25mm UST What is this?
Is that for a line-bored case? ...or a ground crank.
Can't seem to find out a reference... Chris
Measure the OD if you have them in hand. Rubber band the #1 thrust halves together and mic them. You would notice 0.10 thou oversize, or thereabouts. Usually stamped on the bearing too.
Super Moderator
I’m getting 64.96mm
I think that makes the STD OD and undersized ID yes? (It’s for a 3L which has 65mm mains. |
Sounds like it. OD oversize is not common. Expensive too.
