Eng-o-neer
I have it in my head to go crank trigger and coil-on-plug, but it runs up against the very slippery EFI slope rather quickly... |
Reiver
Yes, I got that....my question presently is about the wires.... with a conventional coil can one use spiral wound Clewett style wires or does one have to use the solid stock coppers?
De Oppresso Liber Strength and Honor 5th Legion |
Either will do.
www.classicretrofit.com |
Well we have a design for a new CDI coil and we have been testing on dyno and a few 911 race cars over here. We handmade around 20 for test.
One of our test engines is a Cosworth DFV F1 engine which revs to 11,000 RPM. Originally, these engines had a CDI ignition made by Lucas but they are getting old and unreliable now after years of repair. We are working on re-engineering these units. We just need to find a way to streamline the coil manufacturing.
Reiver
Jonny, If you ever get a schematic of the Lucas CDI, I would be interested in seeing how they went about it, just for curiosity's sake. That's the company that at one time stated they would never use CDI, and nor would they sell ignition components to anyone that did. Thanks, Fred
One of the greatest F1 engines of all time!
www.classicretrofit.com Last edited by Jonny H; 12-09-2021 at 03:10 PM.. |
11000 rpm on a V8 is one heck of a spark rate (733 sparks/second). I would have expected a different design, but with a small discharge capacitor and special coil it could work, or perhaps it switches out one of the parallel capacitors at high rpm? Anyway, very interesting, Thank-you
hi Jonny, any update on the coil availability?
Best, Matt |
Another coil update bump. Installed a new Bosch coil made in Brazil and it crapped out on me today on a drive before i could even fit the cdi+. What options are there outside of those coils for a 79-930?
'79 930 turbo RoW - Oak Green Metallic - k27-7200 Raptor - Kokeln Intercooler - RarlyL8 headers/muffler - Tial 46mm - 964 turbo WuR - Rebel racing bushings front/rear - ER Monoballs front/rear - ER adjustable spring plates - 29/23mm TBs - Vons level 2 - Raised spindles w/weld on racing bump steer knuckle -Wevo engine mounts - Rebel racing transmission mounts - Ruf speelines 17x9-10 - Classic retrofit electric A/C |
Msd hi vibration coil 8222? Can be installed upside down and you can get it in black. Have it in our 72 but also using an msd box though posts here indicate it is a direct replacement. Peel off the decal.
