Like any manual car use the handbrake. Even have to do it on a AM Vantage with sportshift.
Hold the brake till the clutch starts to bite, release it and off you go |
Again... You guys over complicate it
![]() Relax. Leave the brake (foot brake) alone. You are holding the handbrake to stop the car rolling backwards. The light changes so you drive off as you normally would. And once you are moving forward - no need for fancy smancy timing here, let the had brake off. Trust me I've done it a thousand times
Still here
Perhaps, yours is adjusted wrongly ? Last edited by pmax; 02-07-2020 at 11:55 AM.. |
Hand brake use is the correct way: (i) Hold the car with the hand brake.(ii) Release the clutch and apply throttle and at the same time start releasing the hand brake.
Europeans did that for ages, until the current auto hill-assist systems.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl |
When I taught my two daughters to drive, they first had to learn in our 2004 Golf with stick shift. They were first terrified starting on a hill. After a couple times using the handbrake they thought it was cool.
Today they both still drive stick shift cars and they make fun of the hill assist function. They love to drive my Porsche and do it the old way. Juergen
'86 Carrera Cabriolet Grand Prix White '09 VW Beetle Convertible ‘24 Audi Q8 etron |
I prefer the floor it and dump the clutch method myself. But ill admit the parking brake method is a bit more graceful
82 SC , 72 914 |
Yep, back in the Ford Escort days I'd let it roll back until I got up to about 10mph then full revs and dump the clutch.
I don't understand how this has to be said? It was the way I was taught in my first lesson. I had to do this to pass my test. Do people get taught another way? Honest question ... how else would you do it?
RETIRED
Flatlanders and Democrats....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
Don't over-think this and re-engineer the car. Learn the technique. Hold the car with the handbrake, button held in. Release when you feel pressure on the drivetrain. Drive away as if you were on the flat. Sheesh.
Handbrake is the classic method to do this, but in my 911 the pedals are so perfectly placed I can also just do it by doing a sort of heel-toe method, where I can give it some gas while holding the brake pedal, as I ease out the clutch, once the car starts to pull I just smoothly feed the clutch and brake off at the same time while continuing to feed throttle and it'll drive right away.
1971 911T British Racing Green 3.2L 2013 981 Boxster S Aqua Blue/Grey 2014 981 Cayman S Agate Grey/Black enjoyed and passed along: 1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A |
Handbrake. My '78 has a lightened flywheel so stop lights on Seattle hills could be hard on the clutch. Think of it as a handbrake; not a parking brake.
My dad taught me to drive stick shifts on a VW. He used to race 356's back in the day and knew how to work a clutch pedal. He taught me to learn the feel of the clutch pedal, get the real feel of it, so you know it so well that you can just let out the clutch to just the point where it starts to grab, and then hold it there. You can hold yourself on a hill this way, and when it is time to move, just a little gas and start releasing the clutch a little more and you are on the way. I hardly ever use the handbrake on a hill. I never thought about using the handbrake until many years later. If I am at a long light, I don't hold the car with the clutch the whole time, I hold myself with the brake pedal, and then I just anticipate when the light will change and then work the clutch into position a few seconds before.
Craig
77 Ice Green 911s w/3.0 |
Almost everyone drove stick when I learnt; hill start was a standard feature of the driving test. Can't hill start? No license. Take your test in an automatic? Take another test to get a license to drive manual. I struggle to believe some of the habits I've seen folks who weren't taught to drive stick pick up. Like the girl I was riding with one day, going down a long hill, who put the trans in neutral and coasted for about a mile. She wouldn't have it that it was a bad idea. Actually illegal many places...
'77 S with '78 930 power and a few other things. |
Yep, it would wear out the clutch, if I did it often.....
Craig
Still here
