Did you find them online? Or local? (Norway is a bit too far for me, I reckon.) |
45 deg Zerks
Try McMaster Carr
45 deg. 6mm .75 threads male threads https://www.mcmaster.com/zerk-grease-fittings/shape~45-elbow/?SrchEntryWebPart_InpBox=grease+zerks Package of 10 (Less than $13) Straight M6 × 0.75 mm Metric Threads Zinc-Plated Steel 15mm 5.5mm 5.5mm 7mm 10,000 Ball DIN 71412 __ 10 1105K16 3.60 3.09 Package of 10 ( $3.09) Do they come apart for joining one of each? |
The McMaster stuff is cheap enough to give it a try. Thanks, gents! |
Once you confirm those McMaster parts are equivalent and you want to share or sell some of the load, let me know.
In my initial search, I have yet to find the 45 deg. female adapter (5 o'clock) that combines with one of the long straight fittings. http://forums.pelicanparts.com/uploa...1617249390.jpg Sherwood |
The zerks just unscrew from the 45˚ fittings, so you can use two 45’s for an extended 90˚, then add a zerk or long zerk at the end as I did. It can be a little fiddly to get the whole assembly the way you like, I used green loctite on the threads to keep everything where I wanted it. Note that on the first 45 in the chain the hex part is ground down to clear the spring plate, you can just add the second 45 after that one, then the zerk. |
Nope, 45" zerk couplers (to attach a long grease fitting) not available from McMaster-Carr. The existing 45 fittings and appear too short for the torsion tube bushing.
Sherwood |
http://forums.pelicanparts.com/uploa...1617485684.jpg Thanks for confirming two regular 45 deg. Zerks should clear for the torsion bar cover install. Sherwood |
I ordered a 90* fitting for my grease gun and it has made it much easier to grease the PB bushes. So much so, that I'm not presently looking to do the double-45 fitting like Evan has done.
Just an FYI. |
