What muffler do I have? 1980SC
I decided to upgrade my muffler to a Dansk 2:1 in my 1980SC.
Can somebody tell me what kind of muffler i have now? Is it stock? The previous owner did a cat bypass and Im curious what muffler he used. Hoping a 70mm Dansk Sport muffler will fit Sorry for the bad pictures, i couldnt see any part numbers ![]() ![]()
Lada,
You have a one in non stock muffler that looks like someone has fabricated themselves using a generic style muffler as the base. If you want to use a 2 in muffler you will need to change the headers to a two out style like SSI's or similar. I'd suggest you just install a 1 in, 1 out M&K muffler and avoid the cost and hassle. |
go for SSI
saves a lot of weight and heat (no cross tube/heat under trans, no pre-muffler/no heat near valve cover). and the engine breathes more freely (gain of up to to 10hp).
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Thank you both for the info!
Decisions ... decisions |
Wildman Emeritus
I am running a 1 in/ 1 out M & K on my 80 SC and am very happy. When/if I decide to rebuild and mod for more HP, I will go to SSI's or similar.
Looks like some pretty rusty fasteners holding things together, beyond PB or the like. Should be fun getting the old muffler off unless you have a torch.
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
M&k
I will go with the Dansk or M&K. Its not too loud is it?
That may be a Bursch muffler. Through the years they changed silencer brands and shapes.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Can't comment on the muffler but if that's Castrol GTX in the background I'd get rid of it. Garbage.
Walt 82SC 3.0 81SC 3.6 |
Yes it is, 20w50
Been using it for years |
abides.
Graham 1984 Carrera Targa |
So the consensus its bursch and not stock?
definitely not stock -- here's a link to a representative picture of a stock exhaust system/muffler http://forums.pelicanparts.com/6312451-post1.html
That helps, thanks
better pic
