Car wont start
My 1983 911 3.2 wont start. I replaced the plugs, wires, cap, rotor and fuel filter and it sounds like she wants to start but wont.
Here is a video of what she is doing. What should I do? https://youtu.be/FVX0yjE2cLI |
New-ish 911SC Targa Owner
cyl head temp sender? Fuel pump? Both are pretty common and easy to check.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
Can you tell me how to check them both? How would the cyclindet head temp sensor prevent the car from starting?
I didn't realize until i searched your other posts how modified this car is. Lord knows what is wrong with it. Need to befriend a porsche technician and continue to buy them beer. I mean, when you're allowed to leave the house again.
I know that sound and it certainly sounds like a firing order problem. Check and recheck. I know because I always have the same problem whenever I replace my ignition cables, no matter how careful I try to be.
Remember that the 3.2 distributor turns clockwise and the original 3.0 engine that your 1983 came with turns the distributor counterclockwise.
Rex 1975 911s and 2012 Range Rover Sport HSE 1995 BMW R1100RS, 1948 Harley FL |
That confusion explains why I always have problems when I replace my cables and it never starts 'til I find which wires I crossed.
So the car ran just long enough yo get it in the garage. Once in the garage it was doing the exact same thing it is now. I swapped all the electrical in an attempt to fix the issue but it hasnt done anything different.
