Windows Rattle Fix ?
The roads I drive on around my home are very bumpy. Really no fault to the car, over these bumps both windows rattle some, but the passenger window is far worse than the driver window.
Is there a rebuild or repair process to try an minimize the rattling of the door windows? I've heard that anything door related can be a nightmare...so just curious about other's experiences. Many thanks! John |
stick a wooden spoon like you get at the ball park in the carnation malted cup in between the glass and the felt where it appears to be shaking the most.
that's what id do... |
There's a pretty good chance this part being broken in the problem
https://www.pelicanparts.com/catalog/SuperCat/911M/POR_911M_BDYSEL_pg2.htm?highlight_part=901-542-252-25-OEM |
Thanks! John |
If you grab the vent frame at the top and rock it back and forth and there is excess movement, it's probably broken. That part secures the bottom of the frame to the door shell
