-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   While you're in there.... (ver. 69 911E) (http://forums.pelicanparts.com/showthread.php?t=1068279)
Faster_Gun 07-24-2020 12:45 PM
Im finally tearing into my 1969 911E which has been steadily dripping oil for the entirety of my 10 year ownership.
I tackled what I could with the engine in the car a few years ago, two clearly leaky oil drainback tubes on the pass side which helped a lot but not as much as I was hoping.
Anxious to make use of my new lift I put it to work and dropped the engine and trans out of my car this morning.
I have parts on order from our host to address the triangle of death, front and rear mains, and oil cooler seals
Attached are photos as is. I have refrained from cleaning and major disassembly so we can investigate further. Please have a look and request further photos as needed.
Major drips were off the back of the engine case/trans case and the front below the crank pulley. Any preventative maintenance for the MFI?
Oil on the bumper side of the oil tank. This seems strange.
http://forums.pelicanparts.com/uploa...1595619294.jpg
Top of the block looks wet, bell housing has been wet. Ill pull the flywheel this evening and take a look at the rear main.
Cross over oil hose appears to be weaping at elbow/transition to rubber?
Brazing crack?
Leak from this dust boot?
I cleaned this area before I decided to pull the powertrain. I put maybe 20 miles on it since cleaning
Wet in the front pan
GG Allin 07-24-2020 02:12 PM
Is that a "diaper" for lack of a better term stuck to the tank?
dg567 07-25-2020 05:43 AM
Its a stone guard.
