VDO replacement parts
I was taking a part my tachometer from my 68 911 L and found a broken "light chute", a very brittle piece of plastic that keeps the light confined to the indicator. Speedo shops don't want to sell the part so does anyone have a source for these older VDO gauges?
My other ride is a C-130J
This is the perfect part to be reproduced by a 3 D printer.
If someone has a clean one it can be scanned and uploaded to the unit. My Nephew has one. I wonder if he could do it.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
Could you post a picture and dimensions? I can model it in 3d and print it, I have my tach disassembled at the moment and has 3 "chutes" is it the same for the speedo?
Hey guys, my dad (jbell959) an I have been working on a lot of custom gauge parts, including a lot of 3d printing. One thing I would consider is that the stock gauge lights get quite hot, evidenced by the discolored paint on the inside of the gauge face. Common 3D printing materials have low melting points and will likely warp at the very least in the position.
Sent from my SM-G960U using Tapatalk |
lake wales fla
Sounds like you and your Dad are having fun with the gauge stuff, great for you guy's. Again welcome to the forum Richard Danvers |
Here are some photos with measurements. I glued up the pieces the best I could. Note the other 2 chutes are rubber. I bought another tach on line and hope to use the rubber ones to replace my plastic one.
Here is the 3d part, you can download it on thingiverse https://www.thingiverse.com/thing:4551773, also I can print it for you If you want send me a PM.
btw if you have it printed in PLA I would change the bulbs to LED, PLA melting point is 302ºF best regards Jake ![]() ![]() ![]()
"It's only temporary unless it works" 1974 911s turbo-look stock 2.7 engine "Dirty Martini" 1953 replica 550 spyder built from the ground up, EJ25 engine Speeduino ECU |
Jakz, thanks for the link. I’m going to get my nephew to print me one ASAP
best regards Jake
My nephew printed out one of the “light chutes.”
I haven’t gone to visit him and pick it up but he did send me a photo. Sorry for the quality of the photo. Not sure if there was an error in printing it or not. The end seems “unfinished.” ![]()
It seems he did not orient the piece right, looks like it was printed horizontally, layer height quality should not be an issue although it seems a bit high, I´ll print a test piece in the afternoon and post the results
printed it vertically, .28 layer height, make overhangs printable so no supports, 110% scale
Here is a shot of the piece my nephew did. . .
Jakz’s is a little nicer. ![]() ![]()
