Does this look right?
Hi guys,
I'm rebuilding my gear shifter and when I reinstalled the mounting plate, I noticed that the two "tabs" on the plate looked crooked... At the moment the car is still pretty much a bare shell so I can't check the gears by shifting into gear. I would really like to know if I should correct the angle of these "tabs" or if this is just how it's supposed to be? I know for a fact that all of the original bushings had to be replaced so my theory is that maybe the previous owner modified te mounting plate to correct for worn bushings... http://forums.pelicanparts.com/uploa...1601395891.jpg http://forums.pelicanparts.com/uploa...1601395891.JPG http://forums.pelicanparts.com/uploa...1601395891.JPG |
Bueller... Bueller...
Supposed to be vertical but no biggy. On the assumption that the shifting is good I would think that you can achieve the same thing by adjusting the hook on the shifter if it’s visually bothersome.
Cheers, Johan |
Thanks Johan,
The thing is, I'm rebuilding the car so I will be re-aligning everything. I'll correct the angle now the shifter is out of the car. |
If it ain't broke...
How many minutes would it take to pull the shifter later? |
That is correct. Push the shift lever over against the right side and u will see the stick is at an angle that lines up with tabs.
thanks for your input guys
| All times are GMT -8. The time now is 08:16 PM. |
