-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   964 Not holding ignition key (http://forums.pelicanparts.com/showthread.php?t=1074468)
rodeire 09-30-2020 01:42 AM
Hi I have a 1990 C4 and the ignition is not holding the key, you can basically slide out the key when its started, and start the car with any type of key.
Any ideas what has gone wrong?
Classic 911 09-30-2020 04:58 AM
Following
88911coupe 09-30-2020 05:19 AM
My 88 does same thing...will be interested to hear solution.
Mike Andrew 09-30-2020 05:31 AM
Gummed up, otherwise dirty or tumbler springs bad?
dfhtrhjn 09-30-2020 07:08 AM
I would try a lock lubricant before taking it apart.
76FJ55 09-30-2020 12:24 PM
I would guess excessively work key and tumblers.
Dpmulvan 10-01-2020 03:12 AM
It’s the actual ignition Switch not the springs, tumblers (Wafers).
Dpmulvan 10-01-2020 03:23 AM
Might be able to fix it but it’s gonna have to be taken out, replacements are about $650 or might be able to get one off classifieds for $250 $300 ish.
