Yes, McMaster Carr as mentioned above, they're great because they're geographically very close to me. I usually get an order the next day. But sometimes you're required to order 500 of something you only need 3 of.
But I'm curious, is there another online vendor like Belmetric that sells non metric nuts and bolts? I'm putting together a Buick LC2 engine that I've learned has a mix of metric and non metric bolts and studs holding it together. ****** brilliant. I guess GM was in a transition period in the late 80's and this motor's roots go back to the 60's. The hardware store doesn't always have what I need.
-Mark B. Hardware Store Engineer 1988 911 - 3.6 1999 SL500 - Gone 1995 M3 - LS2 - Gone 1993 RS America - Gone Last edited by GG Allin; 12-15-2025 at 12:24 PM.. |
You can try Fastenal and Fastner Supply. I am a fan of McMaster, order early and get ground delivery the next day to NC.
Walt 82SC 3.0 81SC 3.6 |
I’d like to find black interior screws.. door, rocker, etc. But when I search Belmetric and Mc, I can find the right size, finish, etc. Anybody know them?
I drill holes and screw into steel wall stud as a holder.
Tru6 Restoration & Design |
Subd
I’m not familiar with Cerakote…Can I brush it on with a small paint brush?
Amazon has 4 ounce bottles. |
Short of that, an outdoor satin enamel or engine block baked rattle can will work. still need to create a tooth on & in the screw heads
Search up Shaun’s work. It’s drool worthy. Unfortunately, from some of us it would be rendered the lipstick on a pig of a car.
Ass-engine Nazi slot car -- PJ O'Rourke |
Just when I thought I was out.... They pull me back in!!!
You looked in this section? https://belmetric.com/black-stainless/black-stainless-tapping-screws/
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
I’m also looking for the type that fit the concave washers in the door and kick boards. I didn’t see that in the link above. |
My Google-fu was weak….
