Synthetic oil change for the northeast
Can someone recommend a good synthetic oil to use for fall in the Northeast... I am going to change it myself this time... Porsche wants $375!!!
I mean, everyone has their own preference. It's like asking about religion.
I run Amsoil Z Rod 20w50 in mine. I would consider also Mobil1 15w50 also. There are some other acceptable choices that many people run that would also be fine. There's no single correct answer. If you don't feel like you need the synthetic, then Valvoline VR1 racing, or Brad penn would be suitable replacements. If you're not regularly seeing oil temps over 220F you probably don't *need* synthetic oil, strictly speaking. |
20/50 and 10/50 are both good for the fall temps? those both synthetic?
can I go back to regular oil if mechanic has been using synthetic? I was told NO! but never understood why it cant be done...dont believe it. thanks smokintr6 Last edited by jgurnari; 10-06-2020 at 08:48 AM.. |
For the northeast I would never use 20w50, 15w50 or even 10w60. In those cold NE winter areas at deep cold temps the oil would take much longer to reach the important parts for lubrification.
Just look into the TDS from the manufacturers and compare the viscosity value at low temps with values from oils like 5w40, 10w40 or 15w40. You can easely change to a non synthetic one. The other way around is (if its really the case as IMHO its a rumor) more problematic. You have no benefit when using synthetic oil for simple street use. Just change your oil every year, check the CO for proper mixture and everything will be fine.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ |
Driver
Being from LA, I have no FHE. Though I'm somewhat interested in the responses, as I may be moving back to New England in a couple years. FWIW, I'm using the Mobil 1 15w-50. I would think that the 15 weight oil would be OK in a New England fall. I wouldn't think there would be too many air-cooled 911s running around in New England during those 3 weeks in February where it doesn't get above freezing.
I don't think there's a reason why a motor can't go back and forth between dino and synthetic oil. I think there was actually a question in this month's Excellence about this exact issue. The expert opinion was that it's OK to switch. Anecdotally, some people have noted an increase in oil leaks if they switched from dino to synthetic. But there's no real harm done to the motor.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
jgurnari -- few questions / thoughts
1) how do you use your 911? I.e. is it kept in a temperature controlled garage at night? Driven to work and parked outside during the day in COLD weather? I ask this, as I look at oil viscosity requirements as stemming from the environment your car sees, not simply the outside temp. If your car sits in a garage that never goes under 50 degrees, then it's seeing 50 degree oil when it starts. Conversely, if you park your car outside all day while you work and you have 0 degree days like we have in CO, you need to use oil that's appropriate for this environment. 2) what oil (brand/viscosity) do you currently use? I'm a big proponent of "if it ain't broke, don't fix it" -- while I agree that $375 for an oil change is crazy expensive, doubt that the price is primarily being driven by $20 per quart oil . . . . I've personally been happy with the Brad Penn 15-40 partial synthetic my mechanic recommended after performing a top end rebuild on my 3.2 -- At over 100k miles post-rebuild, I'm still getting over 2k miles per quart of oil. Recognize that 15 weight is thick for LOW temperatures, but keep my '86 targa in a heated (50 degree plus) garage at home and treat my 911 very gingerly during warmup when starting up after the car's sat in my office's unheated garage at such low temps for a day. |
the 15 part of the spec is for cold the 50 for hot, It has the right ZDDP spec it has the right weight spec It's available everywhere, I usually pay ~$20 for a 5 quart jug then get a $12 rebate(this years rebate promo has just expired) If you were tracking it and wanted the last 1/10 hp a 15w-40 or 15/4 45 might be appropriate but that also depends on how good your cooling system is
It’s parked underground but not temp controlled by any means. It’s cold in winter but not parked outside.. I will only drive for pleasure in the winter months in NJ.. never in rain or snow but do when it’s dry and cold. The last oil change was not detailed on the receipt or window sticker reminder, all I know Is it was synthetic.
Wow, where do you buy it for $20 .. I found it for $36 at best.
Walmart has it for $25 -- https://www.walmart.com/ip/Mobil-1-Advanced-Full-Synthetic-Motor-Oil-15W-50-5-Quart/20713647?selected=true
Agree with Bill V -- Mobil 1 15w-50 is a good choice for you/your needs
Thats what at least the TDS of big oil companies do say
J300 ![]() J306 ![]() You people will apparently believe anything that any fool posts
1986 Bosch Icon Wipers coupe. |
See the TDS of known oil companies (example table of products sold in germany below) do state that the cold viscosity of i.E 10w60 (bottom of table) is even higher than 20w50: Code:
Name Visko.(mm²/s)/40°C Visko.(mm²/s)/100°C API ACEA Porsche Freigabe ———————————————————————————————————————————————————————————————————————————————————————————————————————————————- 5w40 Beispiele ——————————————— CASTROL GTX 5w40 78,0 13,2 SM A3/B4 Mannol Extreme 5w40 79,2 13,3 SN A3/B4 A40 Liqui M. LL High Tech 5W-40 80,5 14,0 SN A3/B4 A40 Meguin High Cond. SAE 5W-40 80,5 14,0 SN A3/B4 A40 Motul 6100 SYNERGIE 5w-40 85,3 14,1 SN A3/B4 Mobil Super 3000 X1 5W-40 84 14,1 SN A3/B4 A40 CASTROL EDGE 5W-40 vollsynth. 75,0 13,0 SN C3 Mannol Elite 5W-40 vollsynth. 80,5 13,5 SN A3/B4 A40 Liqui M. HT. 5W-40 vollsynth. 90.2 14,5 SM A3/B4 A40 Meguin SAE 5W-40 vollsynth. 90.2 14,5 SM A3/B4 A40 Motul 8100 5w-40 vollsynth. 84,7 14,1 SN C3 A40 15w40 Beispiele ——————————————— Castrol GTX 15W-40 102 14.3 SL A3/B3 Mannol Universal 15W-40 105 13,9 SG - Liqui M. Touring HT 15W-40 101 14,4 SL A3/B4 Meguin HD-C3 SAE 15W-40 101 14,4 SL A3/B4 Motul 4000 15w-40 110 14,6 SL A3/B4 Mobil Super 1000 X1 15W-40 107 14,4 SL A3/B3 5w50 Beispiele ——————————————— CASTROL Edge 5w50 vollsynth. 109,7 17,87 SN A3/B4 Mannol 5w50 HC-Synth.. 99,1 16,6 SN A3/B3 Liqui M. 5W-50 vollsynth. 117 18,5 SJ A3/B3 Meguin SuperLL 5w50 vollsynth. 122 18,7 SM A3/B4 Motul SPORT 5w50 vollsynth. 107,1 17,9 SM - Mobil 1 FS x1 5W-50 vollsynth. 101 ??? SN A3/B4 A40 20w50 Beispiele ——————————————— Castrol Classic XL 20W-50 153 17,3 SF - Mannol Safari 158 18 SL - Liqui M. Touring HT 20W-50 153 18,1 SL A3/B4 Meguin Universal SAE 20W-50 153 18,1 SL A3/B4 Motul CLASSIC 20W-50 164 18 SF Mobil Super 1000 20W-50 146 17,8 SL - 10w60 Beispiele (vollsynth.) ——————————————— Castro Edge Synth 10w60 160 22,7 SN A3/B4 Mannol 10w60 165 22,3 SN A3/B4 Liqui Moly Syn 10w60 168 24 SL A3/B4 Meguin Racer 10w60 168 24 SL A3/B4 Motul 8100 X-POWER 10W-60 163,4 23,5 SN A3/B4 Mobil 1 Extended Life™ 10W-60 152,7 22,7 SN A3/B4 Here the Motul 15w50 comes with 154 mm²/s at 40°C means same cold viscosity like most 20w50. And thats what Im only refering to: the cold viscosity in mm²/s which affects the flow speed of the fluid to reach important parts on cold starts as of the thread starter is talking about using it in NE areas. I dont know which brands exactly do provide their 15w50 with such a high mm²/s vaue at cold temps, but at least someone should check.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 10-07-2020 at 12:18 AM.. |
40C is 104F J300 specs are at -40c to -10C depending on the weight for 15 weight it is -20 or -25C depending on whether cranking or pumping cp is measured
What you're refering to are specs (with no doubt from my side and I know them) but the table and comparison above is what the TDS from the manufactures says regarding the viscosities of their products. based on the viscosity index.
Here a comparison of the range from Motul, 5w40 up to 10w60, ... dino and synthetic. You can use other brands ranges as far as you know the TDS's specific viscosities cSt at given temps like 40c and 100c. mm²/s = cSt ... and the cold values in the brackets are calculated using this tool Calculate viscosity at given temperature | Nimac Great Britain Motul 20w50 Classic (dino) 18 mm²/s @ 100c 164.4 mm²/s @ 40c (2663 mm²/s @ 0c) (7034 mm²/s @ -10c) Viscositiy index = 121 Motul 5w40 (Synthetic) 14.1 mm²/s @ 100c 84.7 mm²/s @ 40c (715 mm²/s @ 0c) (1498 mm²/s @ -10c) Viscositiy index = 172 Motul 15w40 (dino) 14.6 mm²/s @ 100c 110 mm²/s @ 40c (1340 mm²/s @ 0c) (3254 mm²/s @ -10c) Viscositiy index = 136 Modul 15w50 (dino) 19,7 mm²/s @ 100c 154 mm²/s @ 40c (1855 mm²/s @ 0c) (4428 mm²/s @ -10c) Viscositiy index = 147 Modul 15w50 (300v synthetic) 18.1 mm²/s @ 100c 122.9 mm²/s @ 40c (1200 mm²/s @ 0c) (2642 mm²/s @ -10c) Viscositiy index = 164 Motul 10w60 (synthetic) 23.5 mm²/s @ 100c 163,4 mm²/s @ 40c (1505 mm²/s @ 0c) (3412 mm²/s @ -10c) Viscositiy index = 174 As seen above I still would recommend not using i.E. a 10w60 or some of 15w50 oils in NE areas at winter temps. Interesting also the behavior of the same brands 15w50 dino compared to 15w50 synthetic at very low temps, same SAE grade but significant different viscosities. So my point simply is ... someone should not only rely on the oils SAE grade rather at least should check the TDS and the viscosity index, thats what I meant.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 10-07-2020 at 12:51 PM.. |
This is very helpful. No doubt of great interest to those who are about to go into ~0-10C / 32 - ~45F weather for a few months. At risk of being wrapped across the knuckles, can you take a step back and also explain what we’re looking at in terms of cSt and what we should be solving for?
cSt is used here for the value of kinematic viscosity:
https://www.rheosense.com/basics/viscosity-units Btw, ... actaully somehow funny is the part in the link where its mentioned that honey comes with a cSt of 3.500 , so at -10C° even the synthetic Motul 10w60 of above actaully IS "honey" at room temperature. As well as the Dino 15w50 and the 15w40, not mention the 20w50 based on the infos from the TDS's from the mentioned products above. And Im very shure other brands and their customer adressed oils wont differ that much. So less viscosity the faster the fluid moves/flows, BUT thats only one aspect of the relegion of choosing an Oil as we know. But in case of cold environmental temps someone should take care of, .. just my 2 cents.
911 SC 3.0, 1982, black, US model – with own digital CPU based lambda ECU build and digital MAP based ignition control All you need to know about the 930/16 and 930/07 Lamba based 911 SC US models: https://nineelevenheaven.wordpress.com/english/ Last edited by AndrewCologne; 10-07-2020 at 01:16 PM.. |
If it was at the Porsche dealer, it may be Porsche Classic 10-60 synthetic. PCG-043-210-15. Or you could always give them a call.
1989 Carrera Former flings... 2009 Carrera S (x2), 1986 Carrera, 1997 993, 1983 911SC, 1995 993, 1987 Carrera, 1985 Carrera |
shh-the robot is sleeping
I doubt you will drive it when it is less than 20* so it really doesn't matter.
'88 911 Coupe, 69k miles |
| Tags |
| oil change , synthetic oil |
