Make the air cleaner easy to clip together
It is so hard to to clip together the air cleaner halves especially the lower rear clip. When you have the right side cover off attach a 4 mm by 150 mm tie wrap to the clip. Put the cover back in position. The lower rear clip now has a big easily reachable tail that you can pull to the right to close the clip. It is still a tight squeeze to reach in from the right side.
Old 10-06-2020, 05:25 PM
Zip tie extension works for me as well!
A plastic bag over the forearm also helps with more easily getting your arm up past the AC lines.
1984 M491 Coupe
2014 Cayman S
Old 10-07-2020, 03:53 AM
pavegeno's Avatar
Send a message via Skype™ to pavegeno
Great tip! I normally have my son reach in there but he's 13 now.
2002 GMC Yukon SLE - 4AT - Purchased New in 2002
1988 911 Cab - 5MT - Purchased Used in 2005
2008 Cayman - 5MT - Purchased New in 2007
2014 911/50 - #1173 - 7MT - Purchased CPO in 2014
2019 Macan S - 7PDK - Euro Delivery/New in July 2019
Old 10-07-2020, 05:11 AM
Send a message via AIM to roper0621
I only change the air filer when I'm changing the oil, with oil filter out res 03f9 no problem reaching the bottom clip.
Old 10-07-2020, 06:58 AM
Great idea - thanks for posting!
Pete, Park City, Utah, USA
- Experience level: Low but eager to learn
- 1986 911 Carrera 3.2 Targa
- 2018 Factory Five Mark IV 5.0L Coyote
Old 10-07-2020, 06:59 AM
Burnin' Rubber
Koizumi's Avatar
That is a good idea. My right forearm is always scraped up after changing the air filter (even with wearing a long sleeve shirt or some sorta protective wrap).
Old 10-08-2020, 08:56 AM
I always just get my arm soapy and wet as a lubricant to be able to shove it in far enough to get the the zip tie. Something easy to gab and tug on. And get a long and wide black zip tie. A white zip tie might show up visually.
It is one of my most hated tasks to do on my 911. Every 10,000 miles for me.
Old 10-08-2020, 09:02 AM
ABSOLUTELY !!!!
a tie wrap on that connector made it easy to clip the housing.
_______________________________________________
45 yr addiction 1965 356 Coupe, '70 914- POS, '74 911- lightweightFUN, '83 SC Cab- 100%AnalogOpenTop.
Old 10-08-2020, 08:05 PM
