-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   mysterious wire (http://forums.pelicanparts.com/showthread.php?t=1080987)
MyFlat6 12-16-2020 03:14 PM
mysterious wire
I found what looks like a solid black wire that is not connected to anything under the dash.
Here is a photo of the mysterious wire.
http://forums.pelicanparts.com/uploa...1608164049.jpg
76FJ55 12-16-2020 03:40 PM
What year and model car are you working on?
MyFlat6 12-16-2020 04:04 PM
^good point! Should have said this is a ‘72 911T
rwest 12-16-2020 04:25 PM
It’s probably two wires in a outer covering. Did 72’s have a ignition buzzer? Usually that’s the wire that people ask about when they find it disconnected. There would be a jack on the ignition body if your car has the buzzer.
MyFlat6 12-16-2020 06:40 PM
Did some research on ignition buzzer and looks like you may be right.
proporsche 12-16-2020 10:54 PM
if you make a beter pic of the connecter we would know for sure;-)
MyFlat6 12-17-2020 06:01 AM
True - the end is out of focus as I was trying to squeeze myself under the dash to look up :)
It is just a standard spade connector.
proporsche 12-17-2020 06:56 AM
standart for Porsche or not is the question;-))
Ivan
