8 and 10s on 996TT
Hello, I recently got a pair of OZ Alleggerita wheels. They are 8 inches in the front and 10 inches for the rear. Does anyone know what spacers I will need and also if i will need longer lug bolts for a 2001 turbo. Thanks
Old 03-19-2021, 12:19 PM
scumbag
I'd pose that same question over here...but with a bit more info.
Porsche 996/997/991 Forum - Pelican Parts Forums
http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html
https://forums.pelicanparts.com/porsche-cars-sale/1180319-fs-1979-widebody-lightweight-coupe-hotrod.html
AchtungKraft #009 - IG: @doktor_b
Old 03-19-2021, 12:21 PM
Driver
Noah930's Avatar
Do you know what the offsets are for the wheels?
1990 Black 964 C2 Targa
Old 03-19-2021, 01:22 PM
The rears are 40mm offset I believe. Thanks
Old 03-19-2021, 05:46 PM
Driver
Noah930's Avatar
A quick internet search says stock turbo wheel sizes for 2001 to be 8x18 front (40 mm offset) and 8x11 rear (63 mm offset).
So if your new OZ wheels are 8x18 front with 40 mm offset, you should be fine. The rears (8x10 w/40 mm offset) may need a 20-25 mm spacer/adapter. If you use a spacer, you'll need longer lugs. I have no first hand experience, but that's what the math says.
Old 03-19-2021, 06:19 PM
Thank you Noah.
Old 03-20-2021, 01:30 AM
