Why hasn't anyone provided their own comparative dyno tests of the stock Bosch CDI vs CDI+?
When a comparative dyno test is done at the same max advance and RPM, the torque & HP differences will negligible.
Dave |
The goal of this thread is to talk about personalized ignition timing for SCs with a CDI+ or which any another system. The debat is not dual sparks or other ignition topics… sorry… |
Hi Jonny H, I would like to keep the 31 degrees max advance recommended by Porsche. And not to go higher. When I have a look at the Porsche curve in the workshop manual (see picture in my first message), I see that the 31 degrees max advance is met at 6000 rpm and there is 20 degrees at 3000 rpm. So that my question is the following: is it possible to have a flat 31 degrees advance from 3000 to 6000 rpm? Thanks |
Thought I'd pop in the pics of my test rig to illustrate how I checked/and adjusted the rotor phasing:
87 Coupe - The Driver 78 Backdate - The Project http://forums.pelicanparts.com/porsche-911-technical-forum/979976-project-heavy-metal-all-steel-classic-remastered.html 85 Coupe - The Rot Rod! AX beater |
Jonny N here
![]() I am pretty sure he will agree, the stock SC curve is pretty lazy, it is very common for people to modify the advance curve so that full advance comes on much sooner. If you search "distributor re-curve" or the like you'll probably find lots of reading material. Quote:
Very interesting, thank you for sharing.
I notice you do not use the rotor with the RPM limiter. Which rotor model do you use? I would like aloso to remove the RPM limiter from the rotor and entrust that to the CDI+ which is able to limit the engine. |
The rotor is from the 3.2 carrera. 84-89.
Or you can just take the spring and plastic plunger out of the SC rotor. See my video here:
https://youtu.be/GK-gD9_gziU
www.classicretrofit.com |
Hi all,
I think everything is clear now except the "Trigger point" parameter I have to enter in the configuration screen. Sometime people enter 30 degrees or 40 degrees! How can I determine the value I have to enter for my car? Thank you Alex |
You want the smallest number that will put your graph under the red 'keep out' zone.
Grumpy old hasbeen
is the trigger point the number that you have set your static trigger to - by positioning the dizzy?
I feel its not an arbitrary number - but really have not seen it explained - or have I missed something in the documentation?
Perth, Western Australia '74 911 Targa |
Hi Jonny,
Does it mean the number is not linked with the distributor configuration. So that I just have first to enter my curve and second to enter the smallest "trigger point" number that will put my curve under the red 'keep out' zone? Thank you Alex |
Maybe time to go back to a stock 911SC ignition system with a Bosch CDI, right?
Dave |
Bosch CDI is the Levi 501s of ignition, mysocal911. Great gear, and dependable, but it’s what you throw on with sneakers when you just can’t be bothered to be your best.
It’s all about timing on SCs. There really aren’t too many more levers to pull given CIS quirks and the cars respond so well to advance. The difference between 25 and ~30 on my car is staggering. The ability to bring that advance in sooner and customize the curve is worth whatever troubleshooting it entails. Better yet, to dial the timing back when you’re crossing into a state with crap gas. As a compromise, you can do all that while wearing 501s and sneakers in your 911 running classic retrofit. |
You're aware that using a 13mm wrench to adjust a few more degrees of timing is a simple process, and doesn't require spending over $750 and hours tweaking, right? And how about the long term reliability with its overall additional parts count and complexity verse the Bosch CDI? Hopefully, you carry a Bosch CDI as a backup ignition, right? By the way, have you viewed the spark signal with a scope at the coil and compared it to the Bosch CDI?
Dave |
This isn’t the thread to debate the pros / cons of double spark. I think the debate there is interesting, but you’d only be hijacking the OPs thread to have it. The question on optimum timing curve for an SC is a good one and should be left unmolested (for everyone’s benefit). That CDI+ allows you to do that (vs recurve your dizzy) represents competing value, which we each have to weigh up.
To answer your other question, I am running a stock Bosch CDI unit. I used said 13mm wrench to advance my ignition to ~30 and there was a very pronounced difference (vs stock). I’m running richer and have a different cam. Could feel it through the seat of my Levi 501s. I have a classic retrofit unit that I bought and shoved in my frunk for a cross-country road trip as insurance (should my Bosch CDI kick the bucket). I will swap the two and give the Bosch CDI bench duty for the way back. |
If there was an issue with the design of the CDI+ unit we would be inundated with returns which we are not. We have had a couple of isolated manufacturing issues - nobody is perfect, but no issues due to design. None. The notion that you can achieve the same tuning results by turning the distributor and increasing advance across the board is pretty 'basic'. These engines (early cars in particular), respond to increased advance in the mid range as they generally have a flat spot in the power band BUT they cannot sustain increased advance at high RPM without risk of detonation. This kind of curve CANNOT be achieved by bob weights and springs. Part of the enjoyment of owning these cars is discovering new ways to make them better. That's what I do and first and foremost I am a Porsche guy. I have absolutely no interest in producing substandard equipment. What would be the point? For years now, you have been on a mission to derail any thread which has positive feedback about CDI+. I find this completely baffling as I get on just fine with the other CDI rebuild guys. In fact, I just sent a French rebuilder 50 sets of original Bosch internals for his rebuilds. I expect you will requote and pick apart this response in your usual fashion. I won't respond further.
www.classicretrofit.com Last edited by Jonny H; 02-23-2021 at 04:10 PM.. |
Whatever number you set it to, the engine advance should always be validated with a timing strobe as a method of 'dialling in' the settings. For this reason it is not necessary to set it up super accurately static, just get it in the ballpark, start the engine and do the validation in a flat portion of the curve.... I typically make a flat section 'test curve' between 2000 and 4000 rpm - say at 20 deg. Adjust distributor so your timing light reads 20 across this range and you are 'dialled in'. Now put in whatever graph you want. If you change the 'trigger adv' number, you must dial in again. Hope that helps.
I would say go back and thoroughly and carefully re-read the excellent instructions that Classic Retrofit has provided, and like Jonny says, play around a bit but always double check your settings with a timing light. One of the reasons my curve is flat from 800-1200 is for that very reason - I know at any reasonable idle speed my MFI system is in the mood for that day, I can check the timing to confirm it.
At least he doesn't seem to have an interest in air conditioning??? LOL. Cheers, Jon
Thread Tools | |
Rate This Thread | |
