If you want to reduce smoke on startup, let the car idle until the level gauge stabilizes before shutting down. Works for me. Save the $$$$
Kind of Blue
WR Anti Drain Back Valve KIT for 65-71 911 - Willhoit Auto Restoration
Does anyone have the full kit? My line to the engine-mounted cooler is leaking so I think now is the time.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
New-ish 911SC Targa Owner
So there is the Rothsport $$$ valve, and then this WR anti drain back valve for fewer $$.
What do we think about the less Porsche specific check valves? Like Vibrant part number 11196 (uses -16 male fittings instead of barbs but its ~$50
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
As some have stated, risk versus reward. My Porsche mechanic (used to be with Porsche Racing NA) was adamant that it should not be used for the simple fact that if it ever failed for some reason..your kaput
Puny Bird
So he's never tried one, has he even had one in his hands?
The only fail mode is wide open. Think of the valve being like a tiny toilet plunger, with the handle being a solid shaft riding in a brass bushing, so the head (valve) can't cock, it can't go anywhere but in and out. The spring is very light, I'm surprised it can even hold back the oil in the tank. The head is a cone, between the suction of the pump and gravity working on the tank, the valve has no option other than moving open with the flow. Like I've said, I've seen no hesitation on either my gauge or idiot light since installing my RS valve. Having to check the engine while running as recommended, tells you that Porsche knew a lot of oil is migrating into the engine sump. One big bonus of this valve has been the ability to check the oil when the engine is not running.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
