Most stupid annoying task to handel on a 911
As most may have noticed, I'm rebuilding my car. Disassembly is always "easy"...
During the reassembly though you have to tackle all kinds of tasks and some are absolutely frustrating as you first don't get it how it is supposed to be/sit in place, takes time to figure out and then it needs multiple attempts to get it right. I'm actually quiet clever (most of the time) and I work things out, but here's one troublemaker I start the list with for you all to chime in: The gas tank rubber nozzle around the filler neck builds a bridge between the fender and the inner body. Opening the gas flap you see the wide opening of the rubber nozzle. The opening sits in a 360 slid secured by a large metal spring ring. Whichever way I attempt the install this spring ring in that limited space, I just can't snap it in place. Second attempt tonight. If you here a scream then it's due to victory or because I damaged the fresh paint. Maybe you have similar stories to share about what made you go near mad.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Anything having to do with the blower assembly, but especially:
Pass through rubber grommet for heater tubes passing from footwells into front trunk control box / diverters. Positioning them flat, correctly before or after installing the tubes was impossibly unpleasant. Installing cables for heater / blower / fresh air box. Finicky beyond belief to route them without a harsh bend, getting the orientation of the lever end side correct, and the back and forth of adjusting them. |
Eva
Running new fuel lines through the tunnel at home is always a treat.
So is reaching down and trying to get the lower pin through driver side hood strut.
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
The one thing I HATE about my 85 Carrera is getting the air cleaner back together. The back clips are a pain, the bottom rear clip is almost impossible.
I have a zip tie attached to the back side clips, and I can grab those with a finger and get them on, but it chews up my arm.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
To get @ one bolt & nut for each G body front fender, the door needs to be removed.
Two of the nuts & bolts for the front fender can't be accessed because of the oil lines being installed after the front fender was installed.
1980 911 - Metzger 3.6L 2016 Cayman S |
Flojo, this video might help you-https://www.youtube.com/watch?v=EcZfuXIiRK8
That’s not good news... doing the tunnel lines and the rubber filler boot next
Still wake up sweating occasionally thinking about getting that wiring harness in and out of the center tunnel.
Porsche Addict
Sometimes things go wrong right at the time you are ready for the project to come to an end because you
want to DRIVE THE &%$#)@!?% THING!!!! At least we're all rooting for you!
Lawrence - 1986 911 Carrera Coupe Grand Prix White 1959 Land Rover Series II 1962 Volkswagen Sedan Ragtop 1959 Porsche 356A Coupe 1971 Porsche 911T coupe |
6 cylinder symphony
O-rings on the engine mounted oil cooer.
'84 3.2 Targa '89 964 Coupe "What do you mean NEXT project?" - my wife |
High on my list of frustrating Porsche experiences:
- Installing RSR rocker shaft seals without shaving them off during insertion - Installing hood strut lower pins - Removing the cigarette lighter - Removing the rear suspension arms with the engine still in the car - Trying to get the wipers to park correctly - Finding that rattle in the driver's door |
Still here
What's the trick to aligning that transmission mount ?
Full Send Society
Anything and everything behind the dash or having to do with the convoluted vent blower system.
Also Porsche electrical while we’re in WTF territory. |
Fitting a new rubber seal between the oil tank and inner wing, it’s really difficult to apply enough pressure to compress the rubber and get the nuts started.
good listing so far guys!
never mind. I may probably leave it off anyway Quote:
solved that with a small bit of rubber hose.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit Last edited by Flojo; 03-23-2021 at 04:05 AM.. |
Installing the clutch cable clevis pin annoys me every time ...
I had to pull in re-enforcements with tiny hands to do the lower pins for hood struts but my worst so far was the re & re of the pedal assembly and all the connected bits.
Ignition switch...was a major pain. Can't see anything, all by feel. Your hand in some sort of carple tunnel developing position.
www.machine-motorsports.com 1971 911T 3.2 1971 911S 2.5 1972 911S 2.8 1972 911T 2.7 1965 911 300760 1976 911S Last edited by Fubawu; 03-23-2021 at 10:24 AM.. |
Changing a headlight bulb and getting the H4 headlights to stay in place with a new fender gasket....
Oh and don't get me started on the weird spring clip thingies that hold a new glass headlight lense to the housing...
'87 911 Carrera Coupe (go fast, small parts / small kids hauler) '04 Toyota Land Cruiser (go slow, go anywhere, haul everything, the "AntiPrius") |
