Steering Wheel Quick Disconnect and Horn?
Hello Fellow Pelicans...I’d like to purchase a Quick Disconnect for a steering wheel...primarily as a theft deterrent, but it would also be a neat bit of kit on the car. BUT I still want a working horn. There are vids online where owners of other car brands have managed to make this work (Acura and Toyota), but I have not found any solid advice/solution for this on an older Porsche. Has anyone successfully tackled this?
'88 911 Coupe (sunroof delete) / FRP/Carbon Front Fenders & Bumpers / Elephant Racing Suspension / 3.4L Motor Conversion
Old 04-23-2021, 10:23 AM
Cory M's Avatar
You have to buy the right disconnect. I know NRG has electrical contacts, they are also proven and affordable. Lifeline makes them too at a significantly higher cost. There is only 1-2 wires in there, should be same whether it's a Honda or a Porsche.
Old 04-23-2021, 10:35 AM
a.k.a. G-man
Geronimo '74's Avatar
Snap-off QR is what you need.
I love mine.
https://www.murraymotorsport.com/quick-release-bolt-on-6-hole-4
Old 04-23-2021, 10:36 AM
J-Mac's Avatar
I second the Snap Off. It’s the one I use.
J Mac
Current 0
Sold - 67 911T Coupe racecar, 87 911 Cabriolet, 85 911 Targa, 98 Boxster, 95 993 Coupe, 88 911 Cabriolet, 75 911 Carrera #144, modified
Old 04-23-2021, 10:39 AM
a.k.a. G-man
Old 04-23-2021, 10:41 AM
a.k.a. G-man
Get the spacer, brings the wheel closer and helps with horn button installation
Old 04-23-2021, 10:42 AM
This^. You need a spacer to make room.
Old 04-23-2021, 11:03 AM
Thanks guys...do the pulls on the Snap Off get in the way of turn signal stalk, cruise control, etc.?
Old 04-23-2021, 04:56 PM
Has anyone tried something like this?
https://niko-carbonworks.myshopify.com/collections/steering-wheel-accessories/products/external-carbon-fiber-horn-button-kit-with-matte-finish-dual-button
Old 04-23-2021, 05:00 PM
No interference with stalks (turn signal or wipers).
Old 04-23-2021, 05:02 PM
a.k.a. G-man
Looks cool but completely out of place in anything except in a boy racer tuned out pimp mobile, IMO.
You are looking for a QR with the option to connect the horn.
Why would you add this? There is no need.
To each his own and if you like it, why not? It is a bolt-on/bolt-off option.
Old 04-23-2021, 05:27 PM
Just trying to consider all options... I would much prefer a design that at a quick glance didn’t stand out, but I guess the buttons would be counter to that. The look and quality of Rennline product is appealing, but it doesn’t accommodate the wiring. So outboard buttons could be an option.
The Snap Off design has appeal, but I’m not as much a fan of the appearance of the knobs on the side. Can you share a picture or two of the Snap off installed on the car?
Old 04-24-2021, 09:45 AM
1987 Marine Blue 930
1982 911SC
White Plains, NY
Old 04-25-2021, 05:27 PM
It sounds like you want a ring type , as you don’t like pulling nobs .
I can recommend the krontec with deutch connector , but it won’t be cheap .....
Old 04-25-2021, 07:32 PM
i have both FIA approved SPA and a Lifeline quick release with splined collars 20+ years on a couple of cars. they still are tight without play.
i wouldn't go cheap on this one part. all it takes is a miniscule of play which are often found on the hex type collars to spoil your steering feel which can be annoying. if there is any play, it will only get worse.
Lifeline here... im surprise Summit cares them? i thought they were more of a hotrod supplier. I had to order mine from the UK back in the 90's. they arent cheap but you get what you pay for.
https://www.summitracing.com/parts/lfl-410-200-003?rrec=true
Old 04-26-2021, 05:36 AM
Cars and Cappuccino
tdw28210's Avatar
Summit carries some vintage road racing stuff. Bought some TB15's from them.
On the Lifeline, does the part where the wheel is bolted to the 6 little arms have threads or are they threadless and you have to use washers and nuts? Little washers and nuts are annoying and seem pointless.
http://www.carsandcappuccino.com
1987 Grand Prix White "Outlaw" Turbo Coupe w/go-fast bits
1985 Prussian Blau M491 Targa
1977 Mexico Blue back-dated,flared,3.2,sunroof-delete Coupe
1972 Black 911 T Coupe to first factory Turbo (R5 chassis) tribute car (someday)
Old 04-26-2021, 06:57 AM
Burnin' Rubber
Koizumi's Avatar
I also dig the Snap Off. I’ve had one for at least a decade.
Old 04-26-2021, 08:10 AM
RETIRED
Joe Bob's Avatar
Will they work with a stock Carrera steering wheel?
2012 ML350 3.0 Turbo Diesel
Old 04-26-2021, 08:36 AM
My lifeline is for a momo bolt pattern. It use standard momo screws on the face and on the hub I believe. It’s been 20 yrs since I’ve put it on so I’m not certain since the car is in storage. I do have another one, if I can find it I’ll check.
Looks like they have many more configurations now, they only had 3 or 4 different ones back then. The momo adapter was there only “bolt on” street version back then.
The SPA is a racing custom bolt pattern screwed, welded on the steering shaft.
Old 04-26-2021, 10:58 AM
not treads on the finger part, you need a nuts on the back side...
Lifeline Bolt-On Quick Release Steering Adapter
Old 04-26-2021, 11:12 AM
