-   Porsche 911 Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=8)
-   -   The root cause of the flying turd's problems (http://forums.pelicanparts.com/showthread.php?t=110268)
beepbeep 05-12-2003 01:45 PM
Do the water-trick first, it will blow out heaps of soot. [b]then[/d] do the compression-test again...if still low, spray some oil and measure again so you know what kind of problem you are up to.
If you are real cheapskate you could do only one cylinder too :)
