Engine Compartment Blower Motor, no power
I ordered a replacement engine Blower motor as mine is clearly shot. I also so ordered a replacement Temperature Switch on Crankcase Breather Cover as I broke mine a while ago when replacing fuel lines.
I tested the connector to the motor (with defrost on) and there is no power at the terminal. I checked all the fuses in the front and all is good . I dont think the Temp switch would cause the motor to not have power, or am I mistaken. Thanks, Chris 89 Carrera |
When you say "defrost on" are you referring to the dash fan switch? The dash panel switch does not operate the engine blower. The lever between the seats does, pulling up on the lever, with ignition ON. If the lever is what you mean, there are also fuses at the rear fuse panel for the engine blower to check. Also the controller on the engine relay panel may be bad.
Do you have Auto-Heat or a Manual system? The temp switch would probably not cause the issues you are describing. The link above, and the links in the link, have enough info to keep you reading for the weekend ![]()
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires '86 944NA, Sunroof Delete, Track Rat, Full Cage '72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic Last edited by aj88cab; 12-03-2021 at 12:36 PM.. |
I have automatic heat control. Activated by pulling the two heat levers between the seats.
Will check the fuse in engine compartment. New parts dont come until Fridsy |
i wonder if your relay is not good ? Check the power to it this one
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Fuse was blown in the rear. I now have power to engine compartment blower terminals. The two fans inside the car have not come on. I forget if they are supposed to.
Will put it back together next weekend when parts arrive. Not sure how to reach the temp switch on the breather cover without taking off the throttle body. Chris 89 Carrera |
The two fans inside will only come on once you put the engine compartment blower back in and plug its connector. This is because this blower needs to draw current thru the coil around the reed switch. Only then can the reed switch close contacts and let the inside fans be supplied with power. All this happens inside the heater control module pictured above by Ivan.
Thanks Wazzz. that makes sense
also..your 911 have ,on each of the interior blower, separate inline fuse..the fans will only come on the 6th and up postition
check that too Ivan
Dave |
vazzz....did you ask at type 911 French forum? Also what exactly is the small relay you are looking for?Any part number?Or is it the interior part? i have one used-which was open already- also if that is what you are seeking?
Ivan
1985 911 with original 501 645 miles...807 319 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 12-05-2021 at 10:39 AM.. |
Dave |
@ Ivan, yes of course I asked on type911.org. This is where I originally posted the schematic of this module which I traced and drawn last summer. Don't know if anyone here had already done it. I wanted to have a complete understanding of this module operation. Right now the schematic is only hand drawn. Need to find time and skill to draw a cleaner schematic with a drawing tool. So yes the relay I am talking about is one of the two internal relays, the smaller one.
@ Dave, yes, reed relays sometime fail, but mine is ok, I checked it by applying a constant current thru the coil. I slowly raised it up until contacts closed, which was at about 3.5 or 4 amps, so I think it is good. I have spare reed relays anyway. The one I mention is indeed the small mechanical relay, whose coil is shot. So is the coil of the bigger relay. Need to change both. I'll post pictures If I can. |
The relay is poorly designed for reliability!
Dave |
The blower is also temporarily inhibited while cranking. |
Dave |
I'll test the heater and be happy if it blows hot air. I may also try to activate the temp switch (simulate an engine overheat situation by grounding the switch input) and see if the main blower comes on when the car is not moving.
And input the speed signal (pin 1) from the speedo to determine how it affects the rear fan, right?
Dave |
